Does this acceleration seem right for 99 C43?
Is there anything i can get that will fit straight in?
http://ultimatepd.com/upd-55k-merced...000-stall.html
-;ZAYED;-
* I got shifter + TCU/EGS52 from "W208 Clk55",
* cluster from "2000 C43",
* You can go with "W208 Clk55/W210 E55", but that will need to cut the area of trunk/wheel arch, let it fit properly,,
but i went the diff. from "1995 ASD/LSD W140 S350 TD", to avoid that cut..
-;ZAYED;-
-;ZAYED;-
Does it all work straight up with everything else?
that will be need it with newer tiptronic shifter..!
need to change everything stated above, to let 2.82 rear end works perfectly..!!
EGS52 is the only option that can use 2.82 in C43, cause EGS52 can be programmed & coded to any Ratio desired,
wiring are the same in all 722.6 EGS51/52,,
nothing to do with traction, it's all the same in C43..
-;ZAYED;-
Is there any threads around with this info and info on programming the EGS52 unit?
but EGS51 can't be programmable & got a differ married with a VIN# code,
while EGS52 can be programmable & has the signal for authorization with shifter ECM module,
and can be coded to a differ Ratios & differ map..!!
you can't put EGS52, unless if you change "Shifter/Cluster/TCU/Diff",,
other than that, can't be done..?!?!?
-;ZAYED;-
-;ZAYED;-
but for Ratio changing, you will need a good tuner to do it properly..
-;ZAYED;-
to the OP: if your really that concerned- take the car to the drag strip, where you can weigh your car and get split times:
60'
120'
1/8th mile trap speed
etc
thats what you need to determine if or where the car is slow at all. as was already mentioned the heat/humidity/weather can easily affect a 0-60 time by a few tenths.
60'
120'
etc
