C43/55 intake manifold
Anyone wanting some real power and performance contact me and I will set you up with mods that will shock you. Install these and you WILL have the fastest c43 around, with or without the 5.4 upgrade it will be FAST. Just please contact only if you have the funds and very serious.
For those that felt the differences, are you sure one of the manifolds wasnt clogged up bad or malfunctioning???
The manifold I passed on to speed43 which he ported out is a ml55 manifold
These intakes a very light weight considering the size!
i bought a brand new Pierburg from USA.
Anyone that has ever handled a genuine Callaway Corvette DYMAG wheel fitted to the C4 Callaways will have noticed just how light they are for the same reason, when compared with the GM A-Molds, which were pretty light weight too.
Its made a big difference!
(1998 C43 w/ a 2003 CLK55 engine - Wavetrac install starts this week!)
Guess that should improve breathing and I can imagine that with some cams and worked heads we could get some decent extra powerhttps://www.facebook.com/RennsportFactory/photos/a.1748126268818821/2088111238153654/?type=3&theaterhttp://www.rennsportfactory.co.uk/?f...who6bq5h7SPdmg
Last edited by DRBC43AMG; May 23, 2019 at 11:58 AM. Reason: Added image and FB link
(For those that don't know - the 203/209 55 box has round hose ends at the airbox as well as a different shape at the front.)
Guess that should improve breathing and I can imagine that with some cams and worked heads we could get some decent extra powerhttps://www.facebook.com/RennsportFa...type=3&theater
Speedybenz was on the right track but a copy of the SLS intake would probably be the easiest way to have velocity stacks with a dual throttle body setup but an ITB setup sounds like a lot of work and I dont know how to figure out if it would be worth it to even try
