C43/55 intake manifold
Old Jul 24, 2017 | 09:01 PM
W202AMG's Avatar
W202 C43 1999
Hi all,
What is the difference between the C43 and E55 intake manifolds? What is the part number and approximate price?
Old Jul 25, 2017 | 10:56 AM
PJmak's Avatar
Im pretty sure they are identical.
I have a c43 manifold on my 5.4 motor now
Old Jul 25, 2017 | 11:57 AM
cm60k's Avatar
+1,
They are 100% the same..
-;ZAYED;-
Old Jul 25, 2017 | 01:21 PM
DRBC43AMG's Avatar
Originally Posted by cm60k
+1,
-;ZAYED;-
I also confirm.
The EPC gives the same # A113 140 07 01 for either 43 or 55, N. America or ROW
Old Jul 25, 2017 | 03:08 PM
W202AMG's Avatar
W202 C43 1999
Thanks all
Old Jul 26, 2017 | 05:12 PM
benzslo's Avatar
C43 5.4, ML320CDI, Fords
They supercede to the same but the originals were different both in part number and performance. I have both and switched back and forth numerous times, the difference is clear.
Old Jul 26, 2017 | 06:45 PM
W202AMG's Avatar
W202 C43 1999
Which one is better and what is the part number for the better one?
Old Jul 26, 2017 | 11:03 PM
brad_c43's Avatar
'99 C43, '88 560SL
well now I want to know. which is better and how much of a performance difference are we talking about here?
Old Jul 26, 2017 | 11:08 PM
mickey13's Avatar
1999 AMG C43
yeah thats interesting because right now im using the manifold off my 99 4.3 but i have the manifold from an 02 5.4 sitting in my storage. i just didnt want to swap the fuel rail but maybe i have to now.
any idea when the manifold was superseded?
Old Jul 26, 2017 | 11:16 PM
brad_c43's Avatar
'99 C43, '88 560SL
How much power does your car make to the wheels? did the eurocharged tune make a big difference on how the car drove?
Old Jul 28, 2017 | 12:53 AM
W202AMG's Avatar
W202 C43 1999
Is this newer manifold a straight swap on a Euro spec car?
Old Jul 31, 2017 | 04:10 AM
W202AMG's Avatar
W202 C43 1999
Is this the newer version?
http://www.ebay.com.au/itm/302059372958?redirect=mobile
Old Jul 31, 2017 | 05:06 AM
cm60k's Avatar
There's NO newer version my friend, all "M113" intake manifolds are the same,,
don't waste your time on this..!?!
-;ZAYED;-
Old Jul 31, 2017 | 05:43 AM
W202AMG's Avatar
W202 C43 1999
-;ZAYED;-
Ok, so what is Benzslo refering to?
I would like to replace my manifold because at some stage it has been opened up, and there seems to be a vac leak somewhere that is related to the flaps control. The re-sealing job done on the manifold is not overly bad, but sure isnt factory perfect either.
Old Jul 31, 2017 | 06:11 AM
cm60k's Avatar
I don't know Exactly what "Benzslo" meant..!,
the only info. i knew that, AMG used a differ light copper the door flaps & polished the surface of the air bath of first version C43, for their best track time, and that was on "Fab/1998",
also AMG done the same on their special Edition of "Slk55 Black serious" on "Aug/2005" with carbon fiber airbox & MAF housing,,
but there's NO special or modified intake manifold that MB officially provided for "M113"..!!
-;ZAYED;-
Old Jul 31, 2017 | 06:15 AM
W202AMG's Avatar
W202 C43 1999
Ok, well i still need a new intake manifold
Old Jul 31, 2017 | 07:10 AM
cm60k's Avatar
If you have leak in hose only, you can replace it, but this process needs reseal upper/lower together,
this is really the hard point on that..!,,
but if you have leaks in more places, then replace the whole unit & goooooooooo..
-;ZAYED;-
Old Jul 31, 2017 | 07:52 AM
DRBC43AMG's Avatar
^+1
Old Jul 31, 2017 | 10:32 AM
PJmak's Avatar
Whats the best way to find out if you have a vacuum leak??
Without the user of expensive star tool or dealer fees
Old Jul 31, 2017 | 04:56 PM
speed43's Avatar
1999 C43 Amg
What I do is spray carburetor cleaner or the like when engine is COLD. I spray all areas I suspect a leak. If there's a leak the engine idle will rise. Once engine warms up I stop spraying. Sure you can imagine why...
Of course you can also check the Rpm idle needle and see if it moves up and down. A bad air leak will make it fluctuate.
Old Jul 31, 2017 | 04:59 PM
PJmak's Avatar
My rpm needle sometimes moves up and down slightly when at idle.
Im suspecting this means I have a vacuum leak. This would explain my loss of power at low rpm.
Old Aug 4, 2017 | 01:30 AM
brad_c43's Avatar
'99 C43, '88 560SL
Benzslo was right! @alexanderpaul986 did dyno pulls with the older c43 intake and the newer 55 intake and the newer 55 made 12 more HP and a crazy 52 more ft/lb of torque. heres the dyno charts as well
View this post on Instagram
Old Aug 4, 2017 | 02:10 AM
mickey13's Avatar
1999 AMG C43
That's interesting. Is there a thread anywhere about it?
Old Aug 4, 2017 | 06:21 AM
cm60k's Avatar
Hehehe, that's really funny,
i swapped complete 5.4l Engine from "2005 C55" last month into my friend's C43, i pulled out the intake manifold to compare it to mine, NO any difference..!,
put it on dyno, he got (260kW; 358hp), (508Nm 376lb/ft),
i pulled out my stock C43 manifold, and dyno the car after that,,
he got the SAME results..!!!!,
-;ZAYED;-
Old Aug 4, 2017 | 08:30 AM
speed43's Avatar
1999 C43 Amg
I took the c43 manifold apart and ported all the squares inside. Made them a bit bigger and matched the top portion to the bottom one for smoother flow. Than I ported the openings of the intake to the gasket. Than i opened up the ports alot, made them bigger. The difference between the stock and the modded one is night and day.
So maybe the c55 manifold was modified in ways an eye just cant see without taking both apart. Just a thought, would be great if the c55 manifold is better. I would buy one and compare than modify it and see what performance I gain.
