C43 DONOR
I am investigating the possibility of using a C43 donor car (accident damaged) for a transplant into my old W111 fintail... I am comfortable with the complexity of transplanting the rear end in (fabricationwise) and any other structural modifications however my main question is regarding interfacing with the engine and gearbox. I already have a MOTEC M800 ecu that would be able to run the engine but I wonder how easy it would be to run the transmission standalone with something like a TCM-2000. Or would it be possible to transplant the loom etc. From what I have been reading it sounds like too much of a mission as it is tied to the key and traction control?
Any suggestions would be great
Karl
Anyway, don't bother with the C43 transmission. If you're going with a standalone ECU you can bolt up whatever will fit. Hell, you could use a getrag or tremec t56 manual transmission.
What you're asking for the TCU doesn't exist, unless someone out there makes a standalone that works with the 722.6, which I highly doubt. The stock TCU is tied to the ECU, rear diff ratio, ESP, and it's just a huge complicated mess if you try to alter anything.
I would like to say the traction system wouldn't be an issue but I can't say for sure. I'd try running without any traction stuff. Only hesitation is I've seen before where mismatched tire sizes can cause some weird symptoms of it randomly downshifting on its own on the highway. I'd think without the traction system even plugged in you wouldn't have that issue but I cannot say for sure. I would like to use s donor car like that to stock a complete drivetrain into sm older car at some point. Like a 123 wagon.
Good luck?
