Part# Help
Part# Help
Hey guys! Can anyone please help to identify the water outlet fitting on a 1996 C36 water pump? I purchased a brand new Hepu water pump and it has the slot for the fitting but no fitting. I've tried removing it from the old water pump but it is impossible without destroying it as it is aluminum. Thx
Can you identify which part that is?
Part 134 is the seal ring line to water pump A0129975148.
But it seems like you want the fitting that ring goes on?
Part 32 is identified as sleeve A6019920425
If it's not listed then you'll have to buy a small tube with the right diameter and but the seal ring I think.
2014 ML350 4Matic
Part #38 in the parts diagram shows as "grayed out", i.e. not for this model. Part #38 is a plastic drain pipe that inserts into the drain port on some cars, but not the C36.
Thx everyone! So you're saying that I don't need that fitting for the C36 water pump! I'm very unfamiliar with the C36 as it is unlike the C43. I only assumed that I needed that fitting as the current aftermarket pump has it. Thx
