Car Sat With Battery Unhooked, Now Won't Start
Old Oct 13, 2017 | 03:43 PM
KGaniard's Avatar
95 C36 AMG
I am hoping someone may have an idea of what is going on with my 95 C36. Due to a suspected blown head gasket, the car was garaged for an extended period of time with the battery disconnected. When we started to work on it, we reattached the battery, changed out oil and coolant to find there was no stray fluid where it shouldn't be. We decided to start it to see if we could do compression test. Car turns over and just cranks, no ignition. Tried spraying starter fluid directly into engine which had no effect. Hooked up OBDII scan tool (which had previously been able to diagnose other MIL issues) and now that does not connect either. One other time the car acted like this - when the computer got fried due to the lovely biodegradable wiring harness. That episode required purchasing a new computer.
Does anybody have any ideas of where to start? Could the computer have reset itself because it sat without battery connection for several months? Or any other suggestions would be greatly appreciated!
Old Oct 14, 2017 | 02:34 PM
KGaniard's Avatar
95 C36 AMG
My bad - relying on what my husband tells me he is doing to car. Decided to start the car to see if telltale smoke from exhaust still occurred from suspected cracked head gasket after checking all the fluids with no oil in coolant and no water in oil. However the car won't start. It just cranks and cranks like it isn't getting fuel or spark. Checked for sounds of fuel pump priming in gas tank (check) so it seems to be getting fuel but no spark.
