Kleeman Supercharger
Mercedes Benz C230 Kompressor 1999
Roughly, how much does one cost?
And, lets say you had a c43 AMG, and its 0-60 was 6 seconds, if you put the KLEEMAN supercharger on that, approxmiately what would the 0-60 be?
And, i have a C230 Kompressor (kompressor = supercharger), what is the difference between that and a Kleeman supercharger, if i put a kleeman on would i know the difference?
1997 C36 AMG
Re: Kleeman Supercharger
You C230K already has Supercharger unit in which force feed the airintake into the engine to achieve much higher and more aggressive engine combustion === more power..
The kleeman and your OEM supercharger unit are basically different and the same..
What I mean is the supercharger in the general they're all work with the same principal, except many of the have different type and configuration...
The Kleeman unit and the C230K unit is different type, and is designed for entirely different engine..
Kleeman makes the unit available for the V-6 engine and the V-8 engine, which obviously has bigger capacity than the C230K unit..
I could go on and on explaining this, but it is best you do some research first so that you could as the right question..
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
And depending which supercharger type you pick (which type, power band, etc..etc) you should be able to shave about 1 sec for 0-60 time of a C43.
Regardz,
1998 Silver C43
Former Vendor of MBWorld
There are many differances between the eaton SC on your C230 and the KLEEMANN unit for the V8: both are positive displacement which means for each revolution of the SC, it will displace a fixed amount of air. The eaton is a roots-type. The eaton is basically a large air pump which moves more air into the engine- not a true compressor. The eaton also has a higher parasitic draw on the engine at full load as compared to an equally sized Lysholm type. The KLEEMANN unit is a Lysholm type. The Lysholm type is a true compressor, in the sense that it compresses the air within the SC before it is forced into the engine. Lysholm type superchargers are more efficient at high engine speeds, and have a much greater thermal efficiency rating than a roots-type. If your looking for a good book about superchargers, check out Corky Bell's book called Supercharged! You'll find everything you wanted to know about supercharging an engine. Keep in mind it's written by an engineer, so it gets quite technical.
Uber 202
Renntech has a couple of pulleys and kits. Lorinser has a turbo set up. Brabus has a s/c and engine upgrade. Everything cost too much money IHMO. Just by another car if your looking for speed. IIRC the Lorinser turbo kit cost about 10K installed, only puts the I-4 to about 260-65hp and 300 ft lbs tq. I use the MB as my daily driver. I wasnt satisfied with the speed. Even if you MOD the hell out of the 4 banger, you can only do so much. There is a company that will drop in the n/a 5.4L AMG V8 and tranny, for about the same price. I just bought a 3.2L S54 BMW M Roadster, I drive that when I want to go fast.
c43
what was the company that did the swap, I have the inline 6 c280, and i don't think there was any sc for it, might have been a turbo, but I just don't get the kick i really want, if there was a way to drop the 211 e55 amg engine in, that would be a beast, I really like the oldschool body types of the c280's, and I'm not sure but i thought the 202 c43amg was the same size as my c280, so could a swap of anykind happen? mostly if the 211 e55amg could be brought in
