Caliper Guide Pin Bushings?
Old Mar 24, 2018 | 05:26 PM
nkctb7's Avatar
2006 E55 AMG/1996 C36 AMG/1999 C43/55 AMG/2021 Toyota Tundra Crew Max TRD Sport Premium
Hey guys! Does anyone know where I can purchase the ate caliper guide pin bushings? I found one place in Germany and the cost is only 12 Euros. However, they want $109 for shipping to CANADA for four tiny pieces!
Old Mar 24, 2018 | 10:38 PM
nkctb7's Avatar
Originally Posted by Plutoe
Have you gotten off the couch and walked down to your local MB dealer.
I appreciate your more than helpful scarcastic response! For a second, I almost thought that I was on a Bimmer forum as responses like yours are frequent. The answer to your question is yes I have! They don’t have part#’s for the guide pin bushings or caliper pistons. Thus the reason I’m asking for help! I already purchased Centric replacement pistons and genuine Mercedes seal rings. I searched the ATE part#’s and I found the parts in Germany for $15 USD but I don’t think the $95 USD shipping charge is worth the $15 in parts.
Old Mar 24, 2018 | 11:54 PM
mickey13's Avatar
1999 AMG C43
Kowaski is in Germany. Maybe he has some extra in his garage he can send you.
Old Mar 25, 2018 | 12:03 AM
nkctb7's Avatar
Great idea, Mickey! Thx
Old Mar 25, 2018 | 04:20 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Not Germany but Sweden...
Old Mar 25, 2018 | 04:33 AM
DRBC43AMG's Avatar
Just checked the EPC and the parts are visible in the brake caliper diagram, but not listed in the parts list. Guess they don't have them available through the MB network.
Old Mar 25, 2018 | 04:51 AM
cm60k's Avatar
Hey D.,
I think you need (TS/boot set) #: "000 420 00 76",,
these also used in many MB models, not specifically with C43 only..
-;ZAYED;-
Old Mar 25, 2018 | 10:36 AM
KJI3jflarryfe93's Avatar
actually DRBC43AMG aka Danijel from Swizzyland is much more closer to Deutschland than me.
you could also contact Kaype from w210 AMG forum, he is residing in Germany.
maybe he can hook you up with parts as he had lots of brake jobs done before.
if nothing works out for you I'll try to help you out getting these parts from Germany
Old Mar 25, 2018 | 03:22 PM
DRBC43AMG's Avatar
Originally Posted by cm60k
Hey D.,
-;ZAYED;-
Zayed, is that a MB part number?
Old Mar 25, 2018 | 04:41 PM
cm60k's Avatar
Sure Daniel, it's an MB part #..
-;ZAYED;-
Old Mar 25, 2018 | 05:31 PM
nkctb7's Avatar
-;ZAYED;-
Z to the rescue once again! Z, is that part # for the front or the rear caliper pin boot? They are different part#’s. The front ATE part# 11.8171-0022.1 and the rear is part# 11.8171-0015.2. Thx
D.
Old Mar 25, 2018 | 06:07 PM
cm60k's Avatar
Welcome D.,
This part # for fronts, MB uses (2) part #s for fronts depend to the front caliper spec.:-
"000 420 00 76" or "000 420 05 76"
rears doesn't have these boots, isn't..?!?
-;ZAYED;-
Old Mar 25, 2018 | 06:14 PM
nkctb7's Avatar
Welcome D.,
-;ZAYED;-
Hi Z. You’re correct as it is the front only that uses two different part#’s. Are those part#’s for a pair of each or individually? Thx
D.
Old Mar 25, 2018 | 06:15 PM
DRBC43AMG's Avatar
Welcome D.,
-;ZAYED;-
You're right Zayed, the rears don't have those pins as the calipers are bolted directly to the hub assembly.
Old Mar 25, 2018 | 06:23 PM
nkctb7's Avatar
Z,
The second part# is for the plastic end cap that fits on the pin boot. Do you know the part#’s for both pin boots? Thx
D.
Old Mar 25, 2018 | 06:38 PM
cm60k's Avatar
Sure D.,
each # i provided above, contains (boot & cap),,
boot & cap are always together with each kit, not separately..
-;ZAYED;-
Old Mar 25, 2018 | 08:30 PM
nkctb7's Avatar
Sure D.,
-;ZAYED;-
Here is a pic of both ATE boots with different part#’s.
Old Mar 26, 2018 | 12:55 PM
cm60k's Avatar
D.,
your boot kits seems:-
*MB # "000 420 05 76"
*ATE "11.0101-5704.2"
-;ZAYED;-
