Help...I think I Bought a Broken Radio
1996 C36
Hello All, I bought an OEM radio off the web (CM2396) a while back and finally got around to hooking it up. The strange thing is that it will not recognize the CD changer. When I push the CD button...nothing. Just stays in whatever mode it is in (i.e radio, tape, etc.). I know the CD changer works because when I plug in another radio it works (BE1492). When I disconnect the cd changer and press the CD button...it says "none" unlike the one I bought. Can one of you with a 96-98 202 with the OEM radio and no CD Changer see what happens when you press the CD button? Thanks.
hey there, i have a factory CM2396 and also the factory changer if you want to test, i live in emeryville right across the bay. also check the model on blitzsafe website to make sure the adapter if the right model for the HU and also for the year of the car.
1996 C36
