Spark plug recommendation?
I use exclusively Bosch plugs in all my vehicles. For the 43 currently I use Double Platinums
It only took me about 30-45min to swap the plugs out last time and is very straightforward on the M104. I might just try the Bosch out first to see if there is a noticeable difference. I currently run NGKs. I plan on posting back if I notice a substantial difference between the two.I’m currently losing a slight amount of coolant after a spirited drive and some of it is dumping in cyl# 6 which is fouling my plug. I had the car pressure tested about a year ago and there were no issues. The head gasket was changed at the dealership around 50k miles. No contamination and it cools fine. I replaced the cap not too long ago w/ a oem equivalent. Something tells me the intake manifold might be at fault or the heat hose around the back of the engine which apparently has a tendency to leak over time.
Thanks for the input!
