Wheel center caps
Old Jul 24, 2018 | 07:51 PM
silverc4s's Avatar
99 C43, 73 911 targa
Wheel center caps
ok, dumb newbie question. Do you have to remove the wheel to pop out the center cap on a standard MB wheel? These are AMG wheels. I am guessing the answer is yes
Old Jul 24, 2018 | 08:39 PM
hyperion667's Avatar
2012 CLS63
Hmmm, they're stuffed in there pretty tight, and I've always had them off. A tire guy (discount tire) told me once he could have done it if need be. Luckily, it didn't need to be at that particular moment.....I don't know if I'd jab something in there. Perhaps some sort of suction device?
Old Jul 25, 2018 | 03:00 AM
DRBC43AMG's Avatar
I never try to pry out the caps from the front of the wheel. I do it from the inside using the wooden handle of a hammer to gently tap them out. A quick word of warning, place your hand over the cap on the outside when tapping out the cap from the inside to avoid seeing your cap fly out and hid the concrete or other hard surface which will scratch the part...
Old Jul 25, 2018 | 10:52 AM
cm60k's Avatar
+1,
Don't like to remove the caps without removing rims,,
i think, trying this may scratches the edge of the wheel cap..
-;ZAYED;-
Old Jul 25, 2018 | 11:35 AM
cm60k's Avatar
Yeah, you're right occasionally,,
IMO; if anyone need to pull the cap without removing the wheel, prefer to use very thin rubber/plastic removal tool..
-;ZAYED;-
Old Jul 25, 2018 | 11:52 AM
DRBC43AMG's Avatar
+1
