A/C issue
it comes on full blast. This usually only occurs when outside air temp is 90 plus. It sounds like it is linked to manifold vacuum but that doesn't make much sense.
What do you think?
you may have bad Evap. temp. sensor, or not enough gas..??,,
also, did you check the condenser fans, if they working or not..???
-;ZAYED;-
I agree its vacuum related. I've done no digging, I rarely drive my w202 right now.
I think we are on the same page, I am going to try switching some of the vent positions on & off, they are all vacuum controlled. I had switched it to auto control and back off the other day and I think that improved the issue.
If I find a fix I'll let you know.With these 20yr old cars it's something new all the time.
Try this, once you are up & running switch the blower speed up to highest setting for 5 seconds, then back to normal 2 or 3 on blower speed, maybe do this twice. It corrected my problem, hopefully for good.
What do you think?
If this is the case then you may have an "air distribution" problem and , if memory serves me right, there is a vacuum distribution block under the hood in the right rear module box compartment area. It should be black in color and have several vacuum lines connected to it. The block has a steel ball pressed into one end of it and this is usually where it cracks open and leaks off the vacuum.
This is easy to check without connecting any test equipment to the vehicle.
the hood.
There is one somewhere as per diagram attached. If I recall it's somewhere behind the glove compartment once you have removed the thing from the dash area.
