Window regulator failed
I was resetting the window limits after my battery died and I heard a loud bang come from the right rear passenger window. I tore it apart and found the wire on the regulator had rusted and snapped. I can't seem to find the part number for the regulator. Anyone know what it is?
My motor is good, just need the regulator
Can you do a reverse search based on the part number from the AutohausAZ link above? It has a Mercedes part number. The motor is a separate item, so the regulator is most likely in some where with body mechanical.
00 C200 & 00 C55 & 06 SLK55
AFAIK; only Front doors have control modules, "DCM1" & "DCM2",
Rear doors doesn't have modules, only controls via "DCM3" & "DCM4", they're attached to the window regulator,,
and these "DCM3" & "DCM4" controls the voltage of Elec. motors, and also controls the signals of remote locking & (IR/RF) infrared.
-;ZAYED;-
-;ZAYED;-
-;ZAYED;-
-;ZAYED;-
