Swap ECU between cars
Old Nov 21, 2018 | 10:02 PM
W202AMG's Avatar
W202 C43 1999
Hi all,
I have a C43 and an E55, both work fine, both are 99 model.
if i swap the ECU between the two cars, will they operate with their respective keys?
To explain further, the E55 ECU and key used on the C43 and vise versa, as in keys stay with the ECU.
Will that work or does more need swapping? I know that i can just swap the 8 pin security chip, but if that is the same as swapping keys i can just do that.
Old Nov 21, 2018 | 11:58 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
the EIS is mated to the ECU. you'd need to swap numerous other security components between the key and ECU
Old Nov 22, 2018 | 12:01 AM
W202AMG's Avatar
W202 C43 1999
ok, so EIS and ESL would need to swap as well?
Sounds like it would be far easier to just swap out the 8 pin chip that stores the data from those items.
Old Nov 22, 2018 | 12:04 AM
W202AMG's Avatar
W202 C43 1999
What proramming devices are available to modify ECU settings via the 38 pin socket? Are there any PC based programs?
