Strange issue with road vibration
Old Nov 20, 2018 | 01:45 PM
PJmak's Avatar
After the car has been sitting over night and I first drive it the next day it feels like theres a big flat spot on the front tires but I can assure there isnt one and the tires are only maybe less than two years old.
Once I get going after a few minutes it goes away.
Could it be an issue with shocks??
Old Nov 20, 2018 | 02:01 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I've experienced the same thing. What I've noticed is it happens when it is cold out, I have never experienced it in the summer. It's hard for me to believe it is something in the suspension as I replaced literally every front end suspension component when I installed the Vogtland springs
Old Nov 20, 2018 | 04:30 PM
PJmak's Avatar
So you haven't been able to fix yours??
Old Nov 20, 2018 | 05:13 PM
PJmak's Avatar
Originally Posted by Intruder90210
it might be front wheel hub giving you issues.
you have a high mileage C43, things wear, look for play
Hmm Im trying to wrap my head around how a wheel hub could cause this.
Old Nov 20, 2018 | 06:37 PM
silverc4s's Avatar
99 C43, 73 911 targa
Big tires will flat spot in cold weather overnight. If you have stiff suspension it will transmit every irregularity to your steering. I would bet on that first. You could try jacking weight of the fronts overnight in the garage then see how it is when you first start out.
Old Nov 20, 2018 | 07:03 PM
nope. It's intermittent and goes away after about 5 minutes of driving so I haven't chased it down
what do you mean by "big tires"?
Old Nov 20, 2018 | 07:11 PM
PJmak's Avatar
and you replaced shocks too?
Old Nov 20, 2018 | 07:12 PM
PJmak's Avatar
its worth a try but i never had this issue before. I guess ill pull up a few inches before i take off in the morning and inspect the tire.
Old Nov 20, 2018 | 07:25 PM
silverc4s's Avatar
By big I mean 225-245 x 40 or 45 for sure. Not always in one night, but I had a M5 that was always like that after parking for a week in winter
silverc4s's Avatar
It always goes away you said, right?
Old Nov 20, 2018 | 07:47 PM
PJmak's Avatar
yea but my other car that has 19 inch(compared to my c43 18 inch) has never done that
Old Nov 21, 2018 | 10:00 AM
silverc4s's Avatar
I may be wrong, of course. I’m only relating my experience. I also had a bad vibration at speed problem in my 4Runner that I spent a lot of time chasing thru wheels, tires, and suspension that turned out to be a slowly failing universal joint in the main driveshaft.
Old Nov 21, 2018 | 12:54 PM
DRBC43AMG's Avatar
I am of the opinion that they are flat spots on the tyres, which disappear when the tyre warms up. Normally flat spots appear after a relatively long time frame, not unless it is freezing cold. What make tyres do you have on at the moment?
Old Nov 21, 2018 | 01:13 PM
PJmak's Avatar
They are bridgestone potenzas. I never had this issue before and I had this car for over ten years with all kinds of tires. That would be very strange and my other car sits outside too
Old Nov 22, 2018 | 10:57 AM
DRBC43AMG's Avatar
Strange indeed... Just wondering if it could be a faulty shock absorber which judders until the hydraulic oil loosens up when warming
Old Nov 22, 2018 | 11:01 AM
PJmak's Avatar
thats what Im thinking. Its actually pretty bad and the car goes up and down almost a few inches it feels like.
it haplened again yesterday but by the time I drove a couple dozen feet it went away.
Old Nov 22, 2018 | 11:47 AM
I replaced everything, including new bilstein shocks
Old Nov 22, 2018 | 11:50 AM
Your problem sounds different than mine. I don't really feel it in the car, more in the steering wheel. The shock theory makes more sense to me as it would happen when I was daily driving my C43 so flat spots are very unlikely to be the culprit
Old Nov 22, 2018 | 08:45 PM
PJmak's Avatar
Mine literaly.feels like a bad flat spot. You can feel the car go up and down.
i pulled forward a few inches today and looked at the tires and they looked fine.
