TIPTRONIC installed
Old Apr 23, 2019 | 12:49 PM
bullet55's Avatar
w211 E55 AMG-W202C43AMG-w463 G55 AMG
Exclamation TIPTRONIC installed
I purchased ECU , TCU,automatic shifter and the ignition set from a w210 e55 2000 and I install it on my 99 c43 all work well but after 15 minutes time it went to safe mode switch the car off and on it back again same problem will occur , any advice on what to do next.
Old Apr 23, 2019 | 01:20 PM
DRBC43AMG's Avatar
Perhaps you need to program something in the electronics. I imagine Star will be needed.
Old Apr 23, 2019 | 01:24 PM
bullet55's Avatar
do you have any idea what should I program
Old Apr 23, 2019 | 02:01 PM
DRBC43AMG's Avatar
Unfortunately not, I'm not very electronically oriented but someone should be along here later
Old Apr 23, 2019 | 02:29 PM
bullet55's Avatar
I have noticed now that if I'm driving it on low rpm it shift normally once I'm on full throttle it will shift to safe mode .
Old Apr 23, 2019 | 11:50 PM
brad_c43's Avatar
'99 C43, '88 560SL
if im not mistaken, didnt the E55 have a 2.82 ratio? did you change your ring & pinion gear as well?
Old Apr 24, 2019 | 05:46 PM
bullet55's Avatar
im planing to do that next week will keep you posted
Old Apr 24, 2019 | 07:26 PM
brad_c43's Avatar
'99 C43, '88 560SL
I've got a feeling that will fix your problem, let's see!
