1999 C43 Intermittent no crank issue (for going on 3 years now)
PM me and I can hang the document on Google Drive and share.
Hiatus1
Following a complete ECU replacement by a shop in NoVA, I'm having similar issues to Sulaco.
Key worked fine from about 2012-2016, but the battery is not required for starting car. Battery only powers lock/unlock/trunk feature. Try it, your key will start the car even with no battery in it.
What you see in that video is after I replaced ground wire. It's better, but still not completely. It's odd that it improved the issue but didn't completely solve it. I went out today and removed the ground and used steel wool to thoroughly clean the connections at both ends and it made no difference.
It will either do nothing when I turn the key (nothing = starter not engage). Or it will crank and immediately run. The issue appears to be something preventing it from always telling the starter to engage upon key turn.
Tried masking tape on key, no change.
Here's a video I made just now with the windows down so you can hear what's happening outside the car better.
https://www.youtube.com/watch?v=cASR0kIclTI
so I have a 99 c43amg I took it to the shop to have rear main seal, replaced flex disks, suspension work motor mounts trans mount, and fuel filter and hoses replaced. I drove the car to the shop no problems like normal. He did the work moved the car. It sat outside during heavy rain water got into the passenger side floor board he drained it dryed it out for over a week and now the car won’t start. I was originally having the same problem you had but it would start after so many try’s but be super rough that’s why I thought of the fuel filter and was going to suggest the fuel filter but then I looked at your post date which was 2019 did you ever end up finding out what was causing the new start or no crank? Maybe it can help me I also have no communication at the diagnostic port
