1996 C36 Engine Wiring Harness
Old Sep 11, 2022 | 10:41 AM
chutak's Avatar
C36 AMG 6spd; V8 M3
Originally Posted by daryel.corran
just wondering if anyone knows if there is a difference with RHD/LHD vehicles in regards to their harness set-up?
I believe they are different mostly due to wire length to the ECU. The ECU is located in the engine compartment on the passenger side (i.e., opposite of steering wheel) depending on whether it’s RHD or LHD. So the wire’s length from rear of engine to the ECU will vary. These harnesses are built to be a perfect fit.
Everything else where the harness connects to sensors and components, it should be the same given the cars are the same model year and have the same equipment (e.g., ASR, ABS, secondary air pump).
