I Want To Replace Ac- Help Needed
Old Jun 23, 2021 | 04:01 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Originally Posted by DRBC43AMG
So it's the same on all versions
is the receiver drier on the other side on right-hand-drive models?
Old Jun 24, 2021 | 04:02 AM
DRBC43AMG's Avatar
Good question, I'm not sure...
Old Jul 5, 2021 | 01:42 PM
speed43's Avatar
1999 C43 Amg
Well the ac has started working once fcp sent me out another pressure switch. Just one thing though. The electric fans are turning on as soon as I start the car. It's 88 degrees outside and car just turned on. I know this can't be right correct? They do turn off if the ac is off.
Also, my brand new auxiliary water pump is not workig again. I emailed fcp to send another. Quality control seems bad, never had these problems with parts before.
If the auxiliary water pump is not working. Could this be why the electric fans are kicking in so soon?
Old Jul 6, 2021 | 03:28 PM
Sulaco's Avatar
How do you diagnose aux water pump not working? What were the symptoms? Sorry to distract.
Old Jul 9, 2021 | 09:42 PM
speed43's Avatar
1999 C43 Amg
My pump did not pump hot air in winter when the car was turned off..... I just ran positive and negative wires from the battery to the pump motor a d it did not work. Did the same with the new one and it worked.
Fcp sent me a replacement a d will be installing it asap.
