I Want To Replace Ac- Help Needed
Does anyone have any suggestions what to replace so I can do it all at the same time? Also do the Ac's come with oil or do I have to purchase some? Any info to get this done right is appreciated. I'm looking to buy the Denso 471-1293,, unless there's a better one?
Have you checked what is not working? Is the system leaking? Is the compressor dead? Mine didn't hold the charge until a leak test with dye revealed that the condenser was shot. Replaced, recharged and still going good several years later. Good idea to change the dryer capsule at the same time.
Also, once I install all the parts, I can turn the car and not damage anything of I don't turn on the AC, correct?
How do you know its the compressor?
I also changed the water pump when in there, as all the front space was empty. I even removed the aux fans at the same time to get even more access
Thanks again, I have good info to get this done now.
These Bosch compressors are excellent and rarely fail. Even if leaking at the compressor, it's probably a $1 O-ring failure.
You need to know whether the compressor is failing to turn on or if the compressor cannot compress. Important difference.
You need AC manifold gauges to know whether the compressor is compressing or not
Bought both parts and now only get 232 still the ac will not turn on. Sent an email to fcp and they haven't sent me a replacement yet. Still waiting to see if the new switch will work.
