C43 Life
Old May 30, 2021 | 08:42 PM
Benzrider17's Avatar
C43 c55 C63
Old May 31, 2021 | 09:06 AM
99CEEFOURTHREE's Avatar
99 c43,90 mustang gt supercharged convertible,07 acura tl type s, Hummer H3t pickup
Originally Posted by Benzrider17
nice to see you keeping her up . Mine could use a bumper respray as well and thought about a clear wrap
that would protect it for awhile
I tried some 19s ran 10mm spacers all around H&R super sport lowering springs #2 pad ,
Thats exactly what im going to do wrap the bumper,tops of fender and hood.IMHO 19's are too much on a w202.Those wheels are different as mine have a concave.deep design.Thats what i was going for.But those on the white are hot!
Old May 31, 2021 | 09:10 AM
Freshening up the c43 , want to get a few things done this summer keep her running good and looking right .
has anyone did a full maintenance engine and suspension want to order a few recommended maintenance parts if anyone has a list would appreciate them posting it
The calipers look great.Thats exactly what i need to do.What spray did you use? Guess a good prep/light scuff and a few coats should do the trick.Did you hi temp clear over them also?
Old May 31, 2021 | 10:04 AM
C43 c55 C63
Thx man. I took a metal drill brush and got a good amount of dirt and rust off wiped it down a few times then used rust oleum High temp heat
thought about the clear gloss but the spray was hi gloss maybe on the next set 2 coats 10 minutes apart and used two garage bags to cover around caliper
Old May 31, 2021 | 07:25 PM
Thanks brother.
Old Jun 11, 2021 | 09:56 PM
C43 c55 C63
Fixed the gas flow slow flow when I fill up with gas , cleaned up the carbon filter on the drivers side rear wheel well with a little direction from PJ 👍
thx kid. Got it cleaned up and checked at the pump filled up smooth . Gonna keep a eye on it for the next few fuel ⛽️ ups
Old Oct 24, 2021 | 05:20 PM
  #32
C43 c55 C63
Added a Custom plate bracket couldn’t see myself drilling into my front bumper used the bumper bolt to hold the bracket
Has anyone worked on their c43s form has been quiet lately, even at the meets no w202s around
