bump-Please don't flame me. C43,change to C280 springs?
I have a C43 that I drive daily in NYC and the metro area. Those that live here know the roads blow.
Here's the question:
I'd like to soften the ride and lower the car... I know tough combination.
Would it work if I were to swap the stock C43 springs for C280 springs?
And at the same time change my #4 pads to #2's or 1's.
I figure this would help transform this car from the kidney smasher it is now to a bit more complient pothole cruiser. In fact I think it would probably handle better since the road crews here in the East love to place manhole covers right at the apex of most curves... :-(
If this does soften the ride , I would then probably go to 18's to firm it back up a tiny bit...but hopefully not back the AMG firm.
Any opinions would be helpful, I did a search and came up empty on this.
Do I have to buy factory springs from the bend over dealer??
if i remembered correctly...c43 suspension is a little stiffer than c36? u may wanna try that.. of course, c280 springs are gonna be a lot more common...
If that does not yield any improvement my next step will be the C36 or 280 spring set up. Thanks for the information.
Going to the C280 springs, especially in the front could result in terrible bottoming out problems. The front springs won't be stiff enough to handle the excess weight of the C43 motor.
Softening the ride can more easily be done with new shocks. Koni's would definitely be a better step than changing out springs for ill-fitting ones.
