Possible C36 Head Gasket replacement
Disclaimer: I might be wrong and it could blow out sooner than it should - but hopefully I'm right and can help some of you.
ElringKlinger 044.581
https://mbworld.org/forums/c36-amg-c...pre-order.html
I know that usually the actual bore of the head gasket will measure slightly larger to prevent any overhang which is probably why that post says that Elring would make it 92.5mm. That's why I checked if mine actually had any overhang and I didn't notice anything alarming.
