Aftermarket Radio Question
Old Oct 8, 2022 | 09:13 PM
Seed's Avatar
C43 AMG
Hello,
ivr decided to replace my Bose with some aftermarket setups and bypass everything. I bought a blaupunkt radio, some morels jl amp and a sub. The install is relatively smooth although I’m having an issue with the radio.
I wired it all up using harnesses. No spliced crap, red to red yellow to yellow ground to ground etc etc. when I plugged in the harness I was able to turn on the radio with no key. I tested voltage and switched voltage and it was all good. Yellow constant red switched. I’m an old school installer and worked at a shop for a few years in the 90s so I’m not totally clueless but this is a strange one. Any ideas?
Old Oct 8, 2022 | 09:50 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
You could do this in every Mercedes I've ever owned. I can turn on the radio in my 99 C43 without the key. Made for lots of nights in college of parking my car nearby a party with the windows down and blasting good tunes.
Old Oct 8, 2022 | 10:09 PM
Seed's Avatar
C43 AMG
interesting. Does the radio turn off by itself if it’s left on? I can’t remember if the stock behaved this way. I’ve only had the car a few months.
Old Oct 10, 2022 | 12:13 PM
Sulaco's Avatar
After some time it turns off automatically.
Old Oct 11, 2022 | 06:58 PM
importfan21's Avatar
1998 C43, 2017 Honda Accord Sport
Probably related to this? https://rennlist.com/forums/993-foru...-radio-10.html
"The Continental head units needs permanent 12V (Terminal 30) on ISO A pin 7, and switched 12V on ISO A pin 4. These are reversed in the original Porsche car harness."
I know Mercedes' harnesses are like the Porsche harnesses.
