Fixing up my '99 C43 AMG
It has a significant valve cover leak which is no biggie but I also have a list of error codes too.
Is there a good test I can perform for the MAF sensor to confirm it is indeed faulty? (I'm handy with a DMM)
I've chased a MAF issue in the past on another vehicle and the sensor wasn't the problem.
The transmission works 95% of the time but likely needs a valvebody job based on what I've read.
I also have a Cylinder 8 misfire and a random misfire code so I'll start with checking the plugs.
This is the 1st MB I've owned but I'm very comfortable working on cars.
The car has 172k miles and runs great other than an idle throttle surge and the transmission going into limp mode randomly. (again, I know how to fix the transmission issue)
Thank you!
I cleaned the TCU with electronic parts cleaner, replaced the connector plug and hosed the area down with brake cleaner. Limp mode went away, as did the P code.
Sounds like yours also has a clear cut case of bad MAF. Sadly, the affordable options are a crapshoot; you might get lucky or you might need another one in 6 months. The OEM Bosch units are a sure thing but they are pricey, at $400+
Are there any known issues with intake manifold gaskets, ignition coils or injectors I should be on the lookout for when trying to remedy the misfire?
I'm going to start with the MAF sensor along with plugs in hopes that will take care of the misfire codes.
Thank you.
If it's just the misfire codes, from my experience, replacing the corresponding coilpack did the trick. One time it was also bad/stale gas causing a misfire.
But if the misfires are random, almost always points to a MAF. That, or a vacuum leak.
Best thing with everything new is that it will last you many years to come.
All new coils, plugs, wires, MAF, transmission connector and valve cover gaskets.
I figure if I dig all the way down to the valve covers there's no better time to do everything else for ease of access.
But this is a 20 year old, very rare and special car. The best decision here is to replace those ancient wires, plugs, coils, and valve cover gaskets in one big job.
The sensor definitely was due for a replacement or cleaning. It has some sort of rust type corrosion on it, sort of odd.
After replacing that and pulling the battery for 10 minutes she's running so much better.
The idle surge is gone and wow what a difference in performance compared to when I 1st drove it.
All the CELs are clear even after a 50-mile drive.
When the valve cover arrives, I'll snap some pictures of before + after.
ooof, I just noticed the valve cover leavings.
How difficult is it to get the stock remnants off of these heads?
I deal mostly with SBC engines and they typically come right off (mostly because they're 30 years old and soaked with oil) but those look pretty dry considering.
