Laggy throttle response, off-idle hesitation after MAF sensor replacement.
Old Aug 8, 2023 | 06:40 PM
CWBerube's Avatar
1999 C43 AMG
Hope everyone is doing well.
The car was throwing a MAF sensor code and was barely running so I swapped it out.
Reset the code, pulled the negative battery lead and left it overnight.
It runs much better, but it now has a significant off-idle hesitation in throttle response. (No other CEL codes present after taking a long drive)
Example, if you try stabbing the throttle for a quick rev it falls on its face for 1 second then revs up.
If you keep it revved above idle you can then goose it (vroom, vroom, vroom) as much as you want with no hesitation.
Is there a throttle body or MAF calibration sequence I need to run through? Thanks!
Old Aug 8, 2023 | 08:55 PM
PJmak's Avatar
Where did you buy the maf from?
Old Aug 9, 2023 | 01:26 AM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
I did mine many years ago, but it was plug and play. What you are describing is how mine behaved before the MAF swap. After the MAF swap, it ran strong. Perhaps try disconnecting the battery one more time?
Old Aug 9, 2023 | 04:28 AM
DRBC43AMG's Avatar
If it's an internet part purchased at a discount, guess you know why you will need to get another one.
Purchase only OE or Bosch items. They are the only ones which really work without any problems.
Unfortunately, many have experienced the same issue you are faced with now.
Old Aug 9, 2023 | 11:14 AM
PJmak's Avatar
There are some cheap BOSCH branded knock offs out there too.
Its important where you buy from as well. Dont buy from amazon or ebay even if it says Bosch
Old Aug 12, 2023 | 06:36 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Sounds like throttle position sensor failed. But odd that it would wait until you replaced the maf. Suspicious timing
