Ecu Swap With Tuned Ecu
Anyway I removed some good parts on that car. And I removed the Ecu that I had tuned some years ago.
I swaped it to my silver c43. The car turned on and right away it turned off. Tried turning it back on and nothing.
My question is this. Does the housing on the Ecu itself need to be grounded? I ask because I did not remove the stock Ecu on the silver car. I just pulled all the wires and put them on the tuned Ecu.
There are four small bolts that hold the Ecu in place. But it's a pain to remove so that's why I just unplugged the wires and put them on the tuned Ecu.
Those bolts seem to screw on to the plastic housing. But I don't know for sure if that's the case? So that's why I'm asking.
If I can get a sure answer that it has to be grounded than I will remove the oem Ecu and replace it fully correct with the tuned one.
I hope not to hear that the Ecu's cannot be swapped.
Thanks for reading hope to get some replies.
https://themercedesswapshop.com/
I've been working with them to get my ECU coded for the manual swap. It's been a challenge - there are some odd things with the C43 ECU.
I already have the 55 swap. Do you have any videos of it with the manual and LSD? Sounds incredible!
Check out this post for things to watch out for.
https://mbworld.org/forums/c36-amg-c...ml#post8849202
