W202 AMG Picture Thread
Old Oct 6, 2014 | 11:49 PM
  #1851
cm60k's Avatar
Hey Paul, what a great view, can i sit inside the bumper..
ZAYED,,
Old Oct 7, 2014 | 02:31 AM
  #1852
Pagz's Avatar
C43 w/clk55 Organs
Hey Zayed,
If you sit there it will be very windy
I cannot decide to stay with Lumma or go C36, I want something in between..
Old Oct 8, 2014 | 08:49 AM
  #1853
Twichel04's Avatar
1996 C36 AMG and 1999 BMW e46
My new favorite picture of my car from a local Cars and Coffee
Old Oct 8, 2014 | 10:07 AM
  #1854
Demode1204's Avatar
1996 C36
Originally Posted by Pagz
One more for me
Very nice my friend!
Old Oct 8, 2014 | 10:33 AM
  #1855
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
pics from track day a few weeks ago, i switched to running the stock wheels in front halway through the event to give my bridgestone RE-11s a break, the fronts take a beating.
Old Oct 8, 2014 | 12:47 PM
  #1856
KJI3jflarryfe93's Avatar
did you put the wrong caliper/piston on left hub and the wrong caliper on the other side?
switching places on calipers?
how do you like your braking so far with the new front kit?
to bad your cool rims don't have bigger holes to show off your calipers
Old Oct 8, 2014 | 12:56 PM
  #1857
Twichel04's Avatar
Yes, I did swap the calipers side to side. I know that the leading piston is wrong, but I (and others who have done this) have not had any issues with it when it comes to daily driving. If I start to notice any problems, or I start autocross with it, I will switch the piston plates.
The breaks were definitely a much needed upgrade!
For the moment, I have my 17" SLK AMG wheels on it, and they barely fit! It looks like someone stuffed a Laser Disc in there! lol
I will wait till I get a power bleeder to swap the plates though. I'm done with the old fashioned way, haha.
Old Oct 8, 2014 | 02:11 PM
  #1858
when you say: I will wait till I get a power bleeder to swap the plates though. I'm done with the old fashioned way
you mean you gonna change sides on piston plates in correct position?
how do you like the braking?
does brakes bite perfectly?
Old Oct 8, 2014 | 02:30 PM
  #1859
Twichel04's Avatar
If I end up having any issues (or have a day where my ADHD kicks in and I need a project to occupy me) then I will swap the piston plates to the correct position.
The brakes are definitely an improvement over the stock brakes, they bite nicely. However I do wish I had a bit firmer pedal, but I may just need to bleed them again. My wife was helping me and I think she may have taken her foot off a couple times too early. So when the power bleeder arrives, I will flush the whole system.
Old Oct 8, 2014 | 02:31 PM
  #1860
cm60k's Avatar
What are these piston plates you guys refers to..?,
i'm currently using 330x28 Front & 330X26 Rears, brakes are great,,
no any problems till NOW..!
ZAYED,,
Old Oct 8, 2014 | 02:34 PM
  #1861
Twichel04's Avatar
The front and rear sides of the caliper, where the pistons are housed. They can be dismantled and swapped over to the opposite side of the car, thus putting the pistons in the correct position.
Old Oct 8, 2014 | 02:36 PM
  #1862
you might need to get a brake master cylinder from c55 amg which fits the brakes better if you can't bleed the brakes correctly
c36 brake cylinder is not made for newer brakes
Old Oct 8, 2014 | 02:43 PM
  #1863
Twichel04's Avatar
The volume of the c36 calipers VS the c32 calipers won't be that different as they are both 4 piston calipers. If I had gone from 1 or 2 pistons to 4, then the master cal would be a must. But in this case, since the caliper volume itself isn't that much different (its really just bigger rotors) then the current master should be ok. However, after I bleed everything, if the pedal doesn't feel as firm as I want, I will consider it.
To clarify though, my pedal is not soft and squishy. It feel about right, I just prefer a firmer pedal, thats all. The pressure itself feels about the same as before the swap, and the car stops better now than it did before. I'm just being ****, thats all.
Old Oct 8, 2014 | 03:01 PM
  #1864
daem c36 had 4 piston calipers, c43 have 2 piston caliper
Old Oct 8, 2014 | 03:11 PM
  #1865
cm60k's Avatar
C36 M/C may go fine, but agree with Dennis, better if at least go with C43/CLK55/E55 M/C,,
C43/CLK55/E55: 334x32 front & 300x22 rear "VS" C36: 316x28 front & 290x10 rear..
ZAYED,,
Old Oct 8, 2014 | 03:23 PM
  #1866
cm60k's Avatar
There are 4 pistons each caliper, 2 big & 2 small, the piston housing are different in dia., how to switch them..?
ZAYED,,
Old Oct 8, 2014 | 03:27 PM
  #1867
Twichel04's Avatar
ZAYED,,
You take both plates off of one side of the car and swap them to the other side of the car. This puts the pistons in the correct order and leaves the bleeder screw in the upright position.
Old Oct 8, 2014 | 04:05 PM
  #1868
Pagz's Avatar
C43 w/clk55 Organs
Does this leave the brake line facing downwards? (as I see the big piston is on the fluid inlet side so will always make this face wrong direction if piston orientation is correct)
this is 202 picture thread after all... =)
Old Oct 8, 2014 | 04:26 PM
  #1869
Twichel04's Avatar
Yes it does. A special fitting would have to be made. SuperB did this with his C32 brakes.
Old Oct 9, 2014 | 12:19 AM
  #1870
cm60k's Avatar
Yeah, "Super B" did a great fitment job,,
did he switch the pistons..?
https://mbworld.org/forums/c36-amg-c...eed-input.html
ZAYED,,
Old Oct 10, 2014 | 11:08 AM
  #1871
Somalia757's Avatar
1995 AMG C36
To be continued....
Old Nov 7, 2014 | 01:37 PM
  #1872
Pagz's Avatar
C43 w/clk55 Organs
Not mine but worth a post for rare colour and wheel combo...
Old Nov 7, 2014 | 08:20 PM
  #1873
hookah's Avatar
2012 C63 P31 LSD-Current: My past 1999 C43, 2004 Clk55, 1999 C280 sport, 1995 C280
^^ Very nice! does anyone know which wheel that is?
Old Nov 16, 2014 | 03:52 PM
  #1874
PJmak's Avatar
M113 v8
Old Nov 16, 2014 | 07:31 PM
  #1875
PJmak's Avatar
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
