Any modded C43 AMG coupes out there?
i'll take to pop the engine cover off and see if it looks like their 400/450 engine. if it does, the tune will work. i haven't found how much power the tune would be good for.
have to take the car to the dealer first because last time i popped the hood open, the driver side latch didn't want to close. it needs to be adjusted
So far I am very satisfied with the tune. You certainly go through the initial excitement as you notice the new power and after a week or two you seem to get used to it. Keep in mind i am on factory exhaust and factory intake. I think when I eventually get an aftermarket exhaust+downpipes+intake the car will feel/sound a lot better.
Amr tune
#32
I don't think these turbo's are near being maxed out at all. I think companies are keeping the tunes very conservative so early in this platforms life. OE/AMR are targeting max boost at like what, 15-16psi? LOT more boost to go if you ask me. I want to be able to turn it up to 22-24psi.
And I don't think the stock exhaust is any bit of a [real] restriction. Just the cats. Personally, I'm keeping the stock non-PE in place but installing DP's next week.
#33
#34
The CLA is a 2.0L with a turbo big enough to swallow a small planet. That thing helps the 4 banger make more HP per liter than any other production car (that includes Ferrari too). Our v6 very well might be turboed out with where AMR tuned them. The e43 is making more power, but uses larger turbos now. I'm curious to see if the aftermarket takes a liking to this engine and makes a stage 3+ with larger turbos, like they did with the Audi k04 swap. My guess is it won't happen since Mercedes is already planning the replacement straight 6 TT. Time will tell.
#35
They push the k04's to 22-25psi on pump gas (albiet many with meth) and I'm thinking the k04's are slightly smaller than our stock turbo's. Our stock snails should be able to efficiently produce 20-22 psi all day long. Tuners are just afraid to push new engines to hard too fast as they don't want to be the ones to find the breaking point of components and have someone try to sue them for it. I don't blame them to be honest. But we should be able to achieve 400whp with these engines on stock turbo's no problem.
Just basing this on spool characteristics though, nothing else as I haven't seen any specs on them let alone seen the actual turbos.
#36
I do want to find a way to log IAT's this summer and see how the stock W/A intercooling system holds up in the heat. I've asked many companies if upgrades in that department are anywhere in their pipeline and have gotten a consistent no from everyone ![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
It's like by the time this platform is really opened up and becomes a respected car in the tuning world, my lease will be up and I'll be on to something else lol. I don't know if that's a form of Murphy's law, a catch 22 or what, but I do know it's depressing to think about.
