C450/C43 AMG
Lowering a c43 AMG coupe?
Old Mar 7, 2017 | 02:15 PM
ShazV6's Avatar
17' C43 Coupe
Thank you DVision. I appreciate it.
Old Mar 13, 2017 | 05:36 PM
thinkbig12's Avatar
c43
Originally Posted by DVision44
Those are the ones..2 sets of those and you're good!
If I get only one set for the back, do you think it will affect the drive?
Your car looks great btw!
Old Mar 13, 2017 | 07:15 PM
DVision44's Avatar
c43 Amg coupe
Won't be a problem at all...it's all about the appearence you prefer. Thanks for the compliment on my car. She's in the shop getting an xpel wrap. I'm going through withdrawal.
Old Mar 13, 2017 | 10:29 PM
thinkbig12's Avatar
c43
Can't wait to see it
Old Mar 18, 2017 | 02:56 PM
W205C43AMGCoupe's Avatar
2017 AMG c43 coupe
Thanks DVision!
Old Apr 17, 2017 | 06:42 PM
Danieleat's Avatar
C43
Lowering
Hi from the 1st time I saw a c43 it's really bug me why the back wheel are set in arch from the front wheels so when I ordered my car and car I was on the case but really struggling her in the uk as anyone got a part number for the lower springs and 15mm spacers just looking at lowering the back say 1"as anyone done this [img]file:///page1image256[/img]
Old Apr 17, 2017 | 06:43 PM
  #32
Danieleat's Avatar
C43
Lowering
Old Jul 8, 2017 | 10:42 PM
  #33
ryanSTL's Avatar
2017 MB C43 coupe, 2017 Jeep Wrangler Unlimited
just wanted to appreciate all the info on this thread for the spacers from ECS. placing my order now. Car looks great!!
Old Jul 9, 2017 | 10:20 AM
  #34
alexasa's Avatar
c
Careful with that. The ones linked may have the wrong lugs for the OEM wheels.
Old Jul 9, 2017 | 07:12 PM
  #35
ryanSTL's Avatar
I'll be calling ECS before placing my order to make sure, .. since they don't seem to have the '17 C43 loaded into their website yet. I have to return a set of spacers that i never used on my BMW anyways.
thanks
Old Jan 31, 2020 | 03:15 PM
  #36
Matt Rienguette's Avatar
2016 mercedes c450
Lowering springs
Do we need camber adjustments aka camber bolts or a camber kit to go along with the hr springs ??? Sedan c450
Old Jan 31, 2020 | 03:34 PM
  #37
alexasa's Avatar
c
for OEM spec camber. sure.
my tire wear has been perfect while lowered w/o.
Old Jan 31, 2020 | 06:53 PM
  #38
C43HeartBoost's Avatar
C43
How many miles have you put on your tires since lowering? Thanks!
Old Feb 2, 2020 | 10:17 PM
  #39
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Do point out besides no front or rear adjustment (other than Toe - "directional" adjustment) OEM.
Also there is no facility to fit the inaccurate / one offset position Camber bolts (which only offer 0.3 of one degree or 1/8").
We saw the need therefore to FIX IT RIGHT THE 1ST. TIME. No more ongoing trips to dealers or alignment shops or changing tire brands hoping this somehow will reduce the costly premature edge wear.
Re-instating from the early 90's once again precisely adjustable Front Camber and Caster with rear Camber (and extra Toe).
ALLOWING TO ADJUST TIRE CONTACT ANGLES TO SPREAD LOAD MORE EVENLY. Excess edge load also leading to ruptured side walls and rim damage.
Up to 1.5 degrees Positive or Negative - (5 times that of Camber bolts) and more than enough to resolve most premature tire wear issues.
KMAC FRONT #503316-2 J (Full kit price $380). Simply replaces the 4 upper arm inner bushings providing precise Camber and also Caster adjustment.
Easily fitted on vehicle - without arm removal. No special tools needed. Bush extraction tool supplied. Also added security in retaining existing OEM forged alloy arms / not welded, fabricated replacement arms.
Similar kit for the rear Camber (and extra Toe). Replaces lower arm inner bushings (retaining important clearance top of tire to outer fender when adjusting to reduce excess inner edge wear). Also bush extraction tool included #502226K $480
For Performance / Track days also see Web site re uprated bushings for the 6 rear multi link arms along with the '4' front lower arm bushings for extra Camber and Caster - the Caster bushings are Mono ball / 2 Axis (2.5 times load bearing area of spherical bearings that soon pound out). Significantly improving brake and steering response.
Old Feb 3, 2020 | 06:49 AM
  #40
alexasa's Avatar
c
about 10k lowered but had these same tires for about 10k on a c450 not lowered. tires are wearing perffectly.
continental extreme contact sport. 340 treadwear and easily going to last a good 30k all together.
Old Feb 8, 2020 | 01:04 PM
  #41
2017C43's Avatar
2017 AMG C43
Here’s my coupe sitting on KW coil overs
Old Feb 8, 2020 | 01:31 PM
  #42
batman719's Avatar
2019 C43 AMG Coupe
What front splitter are you running there mate?
Old Feb 9, 2020 | 12:49 PM
  #43
2017C43's Avatar
2017 AMG C43
Running Yomato Carbon BRS Style front lip
https://yomatocarbon.com/collections...tyle-front-lip
Old Feb 9, 2020 | 06:11 PM
  #44
batman719's Avatar
2019 C43 AMG Coupe
Never even heard of these guys. Learned something new - thanks!
