Heard someone swapped the E43 turbos onto the C43
Also does anyone know, if all the internal parts for the engine between these two cars are the same? Like did they beef anything else up for the larger turbos on the E43 engines?
there is plenty of headroom with the current turbos and they should, theoretically spool faster and give you more area under the curve when tuned.
Looks like it's a only a HP bump from the C43 stock vs stock while torque numbers remain SIMILAR.
I would say that it might be of interest if you want more top end HP. The trade-off is that the max torque is around 2500RPM instead of 2000RPM.
So HP or torque? Pick your poison!
And if you are truly chasing big power, this is probably not the best way to do. Especially when considering cost/performance (unless an aftermarket company builds a kit).
I'd agree...IF you want 600+AWHP. But then you'll most likely have to start upgrading rods at the minimum. But maybe not as no one knows what is in these 3L's and I wouldn't be surprised if the internals are forged well enough to handle 6, 7, maybe even 800ft/lbs tq. But getting the heads to handle revving out to ~8k rpm's....That's a different story. Usually an expensive story.
Swapping in a slightly larger OEM designed turbo would be cheap and would take away the tq spike we get down low and could shift the power curve up a bit in the rev range as well as add ~50hp without stressing the turbo's.
But on that note, I doubt we're stressing the turbo's as of yet. I believe that OE/AMR's tunes only, and correct me if I'm wrong, push like 13-14psi; that is certainly not stressing these turbo's. Not even close.
What isn't on these cars?
One is RWD. The other is a larger and heavier vehicle all around.
Whew!
I've been waiting for these types of threads! I'd love to keep this car after lease end if the aftermarket has advanced enough. So far, it's slim pickins...
$5000-8000 for 2 turbos
$3000 labor
$2500 custom tune+dyno
$N intercooler
etc
etc
Why not just buy a Tesla for this amount of money? Or any other car that tuner friendly.. C43 is not a tuner car..
E43 turbos seem to be a straight bolt-on, although expensive ($4400). Hopefully, an aftermarket company, like Pure Turbos, will develop an M276 turbo upgrade path for more power and cheaper.
So just to clarify, it's actually the piston assembly part numbers that are different...which consist of the rings, wrist pin, and piston. If any one of those parts are different then the part number for the whole assembly should change.
I suppose it's possible for Mercedes to have just changed rings while keeping the same piston to free up a tiny bit of power.
