C450/C43 Wheel Fitment Guide
#301
Understood now, thanks for the information. Trying to learn all of this as quickly as possible, feels like drinking from a fire hose. Appreciate all of yours insights.
#302
Well, I've worked through urotuning.com and Discount Tire to confirm fitment with TSW, and they've said the 8.5 32ET will work on the front, but they are insisting that the 9.5x39ET will be too aggressive and stick out too far in the back. They are saying I would need offset in the rear of around 50.
Thoughts on that?
Thoughts on that?
#304
Believe I’ve come to an agreement with Discount Tire that Vorsteiner VFF107’s will fit.
Fronts are 8.5x30 (edit: based on alexasa’s post I should maybe go with 35 offset?)
Rears are 9.5x46
Going to let the manufacturer confirm that for me tomorrow when I call them, but my guy was told they were made to fit W205’s should should be good in some fitment.
Way more than I intended to spend on wheels, but it is what it is...and hopefully they hold up better than the ****ty AMG cast ones did.
Rears are 9.5x46
#307
#309
#315
C43 Estate
Check out this guy's wheel fitment on a C43 Wagon.
Fr: 20 x 8.5 ET30
Rr: 20 x 10 ET48
What do you think his tire sizes are?
Fr: 20 x 8.5 ET30
Rr: 20 x 10 ET48
#317
Some tuners seem to be offering 8J front and 10J rear, would running 225/35/20 front and 265/30/20 rear be okay for the 4wd system?
#320
#322
Fantastic. It looks good.
I’m getting really close to zeroing in on a set of 20” staggered wheels now.
Front: 8.5 x 20 ET33 235/35-20 (rolling diameter 26.5”)
Rear: 9.5 x 20 ET44 275/30-20 (rolling diameter 26.5”)
Non lowered suspension.
Do you think the fronts will clear the front strut?
#323
2016 C450 AMG
Has anyone fit the 19" forged C63 coupe wheels on a C63 or C450 sedan? The following specs are what I'm looking at:
19x9, et 25, 255/35/19 Front
19x10.5, et 57, 285/30/19 Rear
This would be on stock ride height. I believe the beginning of this post was saying that the coupe wheels are too wide for the sedan. Is that correct?
#324
#325
2016 C450 AMG
thanks. that's what I thought.
Anyone have thoughts on this setup:
Rohana RFX5
19x8.5,et25, 225/40ZR19 Front
19x9.5, et47, 245/35/ZR19 Rear
Tires would be Michelin Pilot Sport A/S3+. Stock ride height. Seems like the tires would be stretched out given same stock width on a wider wheel? This is the "optimal" fitment that the vendor is suggesting though.
Rohana RFX5
