Running drl at night
Hi! I'd know if its possible to run the drl as i wich. Turn off the low beam at night to roll on drl.
I was able to Do this with the OEM switch on my b8 S4 but wondering if i can Do this with the benz
I have a c43 amg 2017.
Thanks !
Thanks !
not sure why you would only use a DRL at night when it will give you next to no visibility past maybe 10 feet. i understand for pictures, but you seem to be trying to drive like this. considering you cant figure this out on your own and this is the question you are asking i am going to not answer this as you are clearly pretty thick. this is to protect you, and mainly others on the road.
sorry for my aggressive response but there are a lot of idiots on the forum and i would rather advise safe info than reckless.
to use drl only turn your light switch from auto to the amber on only. You cant get drl only but you can get drl with side amber and no head lights.
