Stock Height 18" Stock Wheels Spacers Needed
I am on stock 18" wheels and stock height, from what I have read I need the following,
12mm for the front
15mm for the rear
Can anyone CONFIRM this?
Also do I need any additional bolts to use with the spacers?
For rear 12-15mm would be flush. yes you would need longer bolts. stock bolts are 27mm length so add your spacer thickness to get bolt you need. so for a 5mm front you would need 32mm bolts round up to 35mm for nearest size. and for rear you would need 42mm for 15mm spacers round to nearest size you can buy 45mm bolts.
Now I am not too sure
you cant go wrong with 12mm in the back. make sure to get a special type spacer as mantioned in numerous spacer threads on here.
