11.97@116.68mph - jb1, the rest is stock!
JB1, map6
Stock DP
Stock run-flat tires
Stock oil*
93+ fuel (~1/2 tank of 93+ a can of octane booster)
Temps in the mid 50's
*The car currently has a total 9,200 miles, around 8,000 of which on jb1..... it's due for the 1st oil-change/service soon.
11's run
All runs
Weather
Basically, except I can pull this out in 5 minutes before going in for service or when selling/returning the car..... The down side to this, it doesn't remove the top speed governor, which I don't care for. When the last time you needed to go over 130mph?
Trap speeds what I normally look for (1/4 -1/8th speeds). The car with higher trap speeds should always be faster from a street roll. ~1-2mph traps shouldn't make a huge difference, but 3-5+mph will. Also on the streets, if you tree someone of the light by a car or two, they need 50-100hp just to catch up. The rest (60', 330, E.T. etc..) is just a matter of practice. R/T (reaction time) does not really count unless you're bracket racing, the timer doesn't start until you move and break the beam.
Don't expect to head to the track and lay down 11's or even low 12's immediately. I've done this a few times and while it's a "straight line racing", every little thing on the track can make a big difference.
Earliest pic I can find of me practicing, I believe this was from 1999 at Englishtown.....
Sad to see it closed
Having the Bluetooth enabled me to log my track runs and dial-back boost in areas where it was actually hurting my runs. This map is basically a slightly modified map2
Thanks, yes jb1 only and I believe it's the first C43 in the 11's with an official track slip!
