Problems/Review of new 2018
Hello, I picked up my car 6 days ago and have already run into many problems as described on this forum before. They include:
- Chattering windshield wipers, usually in light rain/lubrication conditions
- Brake pads squeaking, only very slightly nothing loud
- Excessive brake dust, given that it was quite rainy this week 4 rotors looked like they went to ****. I cleared it off by braking medium-heavy on the highway it seemed to have cleared it off and they look clean again
- Brake calipers/pistons sticky, perhaps a combination of the rust as described above the pistons did not seem to retract all the way and were slightly engaged. I heard light screeching and friction when accelerating
- Sport+ jerking in low gears during "stop-and-go" traffic, Major problem. When rolling/braking to a stop in Sport+ (relatively high rpm ~2k-3.5k), then applying light gas, remove foot from pedal, and applying light gas again car violently lurches back and forth ~3 times as if I accelerate hard, brake, accelerate, brake, accelerate, brake... Continues as normal after a couple of seconds of slowing down with foot moved back on brake pedal for safety reasons. Extremely dangerous.
- Automatic parking brakes (e-brakes) do not always activate, when turning off the engine the e-brakes do not always turn on. Could possibly be due to the car not "warming up" to desired conditions similarly to how Start/Stop function only works when ready
It is a shame I have had this car for less than a week and am able to write a list of problems this large. Had it custom ordered and waited months for it. It is still in break-in period (600km) but I had to let 'er rip to do some "testing"
Overall, general driving in comfort is good. I can withstand the clunky downshifts during braking (to the point where I barely have to brake to slow down) and the harsh suspension with POS run-flats allowing me to practice swerving.
Something I don't appreciate is Mercedes' money-saving scheme of utilizing run-flats to avoid giving out jack stands, lug wrenches, and basic kits. They are making money off people who have to call in to use their in-house roadside assistance when otherwise they would do simple repairs themselves.
I will share photos when I have the time in the following week! Thanks for reading and feel free to add your thoughts.
2021 Mercedes C63s AMG Coupe
- Should be an easy fix for mercedes
- Everyone has it, characteristic of high performance brakes. My friends 440i does the same.
- Same as above
- Software to fix this is already out. Have the transmission updated
- E- brakes turn on after you open the door.
- Same as above
Also the E-brakes sometimes turn on without opening the door but just parking the car. Not sure why but it seems to be 50/50.
Cheers.
Regarding the tranny update, are there any downsides such as lower hp/torque or less bangs? Is there any reason some dealerships don't apply a software UPDATE, could this imply that it is merely a quick fix by Mercedes HQ?
Cheers.
Cheers.
If it makes you feel any more comfortable, you are describing issues that a vast majority of C43 owners have on here. None of which I might add have negative impact to the car.
- windshield wipers do chatter on this car, complain and they will replace them though
- brakes, performance brake like these are noisy in general and brake dust is very common
-jerking will go away over time because 1) you will learn how to avoid it, which is not difficult once you get the hang of it and 2) the software in the car is built to learn your driving style and will try and optimize its performance towards your style.
overall, in my opinion, all of these issues will fall by wayside as you grow with the car. I hope you enjoy your new car!
Nicholas Lopez (02-24-2020)
Interested you say this. About the fix for the transmission. mine is a 2018 c43, delivered jan 2018, and it still jerks in sport+ like the OP described. Wouldn't they have fixed this as standard - or do you still need to ask for the update?
Yeah it is very strange how the newest revision doesn't have this "update" even though Merc has known about this for years. You will need to bother your dealership to get it updated from what I've heard. My sales associate is having me take him on a test drive to recreate the problem.
This problem never gets resolved 100%, regardless of the updates you get. It has to do with some throttle response mapping and MB f*****d this up. I'd recommend shifting up a gear, or letting off the gas when you see bumpy road.
Sport plus isn't needed in stop and go traffic, so it's not something they really care to fix. The throttle is overly aggressive, yes, but that's why you have 3 other modes with more linear response.
The wipers chattering needs the windshield polished, there's something on the cars that causes that, a chemical or coating, that once cleaned off seems to be good. New blades will be very temporary fix.
As far as the brakes, most of what you are complaining about isn't anything, the car got wet and the brakes got rusty? Like every other car?
The following 2 users liked this post by ItalianJoe1:
C43Ayemgee (04-05-2018),
The update came out around December. Just go to the dealership and check just to be sure. Everyone in our group who has the new transmission update does not have this problem anymore.
I don't think these are problems.
I have all of these, but its just how the car is..
The windshield wipers are fairly new so they should stutter a little till they're a bit used up
The performance brakes do leave brake dust, but can't avoid that in any car.
Sport+ is jerky from a stop in first gear because of the power, you have 384lb tq @ 2krpm and you're in the fastest/most responsive setting in the car which is a 9spd with short gears, so it will jerk if you tap the gas, the car wants to go. You shouldnt be driving/cruising in sport+ if you intend to drive like a grandma. Drive fast or put it back in sport/comfort.
Snarfalus (04-05-2018)
I agree, on top of the fact in stop and go I am always in C or E, but does anyone here drive in Sport+ without having it in M? I hate the artificially high revs everywhere, it is annoying. Just keep it in M and Sport+ to the OP, and it will be smoother.
Thanks for the replies everyone, just to reiterate, I don't think all the points listed are problematic.
I will try to get the fuel map and TCU updates in the future.
Perhaps my seat adjustment and granny-driving got the better of me, a lot of it is driver induced. I now put it in Sport mode more regularly and can control the throttle better. Just hit 1000 clicks.
And to the people who say to just drive in Comfort or Eco, the reason people like to drive in Sport+ is for the performance exhaust valves to fully open. Without any aftermarket modules, the valve opening varies with engine RPM.
Finally, another annoying feature that's hit or miss is the Keyless-Go lock sensor. Hate that thing! But I read through the manual and it states specifically to place your finger only on the sensor and nowhere on the handle. Give that a go, so far it works more consistently.
So i learned that you dont actually press the button on the handle. You need to glide/swipe your hand across the door handles, works 100% of the time.
i was like you at first, trying to press the button and getting frustrated that it isnt accurate. But i guess mercedes programmed it so that you must swipe your hand across the handles
I operate mine with a swipe of the back of my fingers as I walk past my rear driver side door (I back in to my space up against a sidewalk). The only issue I encounter is during the winter time. My first touch to the handle always has a static shock and won't register the touch at first. So now I'm in the habit of a quick tap-release-swipe motion and have no issues.
The thing about the rodeo problem is, the car is super sensitive in Sports+, it doesn't like nervous movements of the accelerator. If you are second guessing it, it will happen. If you press the accelerator confidently, it never happens. It didn't happen to me a lot pre update anyway. Then my friend got it and it did it all the time when he was driving it. So it is pretty apparent it is a driver problem mainly. With me, after the new update, it did not happen even once.
Any downside to the update that you perceive?
jonathan358 (04-12-2018)
