C450/C43 AMG
Tire Pressure?
Old May 1, 2018 | 08:33 PM
Snarfalus's Avatar
Top Answer: 1
2018 C43 Sedan
Tire Pressure?
So max tire pressure as posted on sidewall is 51psi for fronts. Reccomended per gas sticker is 42 and on the road my tires hit 50. Cold pressures are measuring higher than recommended. Also felt like there was not enough grip car felt sort of unplanted. Should I bleed off some air? This is the warmest day so far this Spring by a good margain and I definately felt car was different. I’m sort of uncomfortable hitting max recommended pressure although I realize that value is COLD and tires were baking in the sun all day.
Old May 1, 2018 | 10:18 PM
AMG C43's Avatar
C43
39 cold. Never run max pressure.
Old May 3, 2018 | 02:11 PM
HTXgearhead's Avatar
2018 C43 sedan
Tires should heat up roughly 3-4 psi from cold temp to on the road temp. Take 5-7 psi out and give that a shot.
Old May 3, 2018 | 02:20 PM
Snarfalus's Avatar
Top Answer: 1
2018 C43 Sedan
So I did lower it to the recommended PSI and it does handle much better now.
Old May 3, 2018 | 02:28 PM
Snarfalus's Avatar
Top Answer: 1
2018 C43 Sedan
I think they overinflated for transport.
