New rotors and pads 13 days after delivery; a brake(s) saga
The only thing that appeared a bit off was the fact that the brake rotors had quite a bit of rust on them. Furthermore, the rust wasn't just your typical orange rust, it was black rust that almost looked like baked on pad deposits mixed with rust.
Now, rotors and rust go hand-in-hand, so I thought that all the rust would get knocked off the rotors during my first drive home. I was wrong. It ended up taking nearly 200 miles to start to knock the baked-on rust deposits off the rotors. 200 miles of hard braking.
Once the rust started to diminish somewhat, I noticed that I could feel some ridges along the faces of both of my rear rotors. I feared that the rust deposits interfered with the ability for the pads and rotors to interface/wear smoothly over the course of that 200 miles. In addition, I would hear some strange noises and feel some mild vibrations when fully applying the brakes at parking/reversing speeds. I'm guessing this was the result of the ridges on the rotors.
I explained the situation to my local dealer and both the Service Manager and my Service Adviser absolutely knocked it out of the park for me. They were able to make a warranty claim that covered brand new rotors, pads, and hardware for every corner of the car.
I had all of the new brake hardware installed yesterday and when the technician pulled the old rotors off, we noticed moderate corrosion on the inner portions of the rotors (which was not visible with the brakes installed). After seeing the corrosion, I am beyond thrilled that I pursued new brakes. I was super impressed by how Mercedes-Benz, and more specifically, my dealer, handled this entire process. Some of the best customer service I've ever received.
Will have more updates when I pick up the car later this morning.
Moral of the story: If you're buying a car off the lot that has sat in a hot, humid, and moist environment, keep a close eye on your brakes. On these cars, full braking performance is a huge part of the experience.
Photos of the old, factory-installed rotors + 1 photo of a freshly-installed, NIB rotor:
Yes sir.
And when the rust finally started to diminish, I started feeling the ridges on the rears.
I finally just said, this is nuts, I'm not accepting anything less than a full replacement of all this hardware.
Before, when using my old, factory-installed rotors/pads, the brakes were almost like an on/off switch. The stopping power was there initially, but they started to let go a bit the deeper I got into the pedal.
With the new setup, the brake pedal feel is much more linear and progressive. Initial bite is good and I can precisely dial up more bite with additional travel. The pedal feel is stronger and more confidence-inspiring the deeper I get into the pedal.
In short, these brakes feel much more analogous to the setup on my old W204 C63. That is a huge compliment to this braking system, as the C63's brakes were among the best and most consistent I've ever used on a road car.
World Wide Motors is the dealer.
