C450/C43 AMG
JB1 and 0-60 times
Old Jan 3, 2019 | 04:24 PM
gabemcclintock's Avatar
2019 C43 AMG
JB1 and 0-60 times
I recently bought and had my shop instal the JB1. It seemed to add a little more power but I've been wondering if that's just me telling myself that it feels more powerful. So I bought a Dragy unit and went out the other night ran some 0-60 laps to see. Driving a 2018 C43 Sedan with AMG exhaust.
Now a few asterisks on these runs:
- Located in Calgary, Alberta (3400 feet about sea level)
- winter here so temps were around the 3 degrees celsius / 37 fahrenheit
- on SottoZero 3 winter tires
- running 91 Octane
- using default Map which I believe is Map 2
Fastest verified run was: 4.58 seconds
Seen vids online of people running under 4 and can assume it's on summers, warmer weather and 94 octane gas and lower elevation. I was in Vancouver, BC (at sea level) a few weeks ago, filled with 94 octane and the car seemed REMARKABLY faster but didn't have any way to time 0-60.
My question is, should I be expecting faster times with the above conditions?
Old Jan 3, 2019 | 05:01 PM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Many factors play a part in achieving the full potential the car is capable of. Temps, DA (air density altitude) and fuel are three biggest external factors, especially with the JB1/4. The fastest times are a full second faster that what you've posted, but using a car/region-specific map6 boost table. As of this post, your DA is +/-1400ft (https://airdensityonline.com/track-r...strol_Raceway/). This is overall similar to my Fall DA and I could regularly pull 3.8-3.9sec 0-60s. Munis is in Toronto and he's pulling sub-3.5sec. Another guy in SE Asia has a much higher DA, but runs a meth kit and is pulling similar numbers. Work on a custom map6 and find some 93+ octane or run an E30 blend (4-4.5g E85, the rest 93) and you'll see big changes.
Old Jan 3, 2019 | 05:03 PM
Also, you can use this site (or download an app) to check your DA and load up an appropriate custom map6 depending on conditions.
Old Jan 3, 2019 | 05:05 PM
2019 C43 AMG
Thank you for taking the time to reply.
So I have to ask as you seem to know a lot about this, do you feel that what I am getting in terms of my 0-60 times, with the factors I mentioned (winter tires, gas, temp, etc) that the JB1 is actually adding power and speed? Should I be getting faster times?
Old Jan 3, 2019 | 05:10 PM
Closer to sea level, on summer tires, summer fuel blends, bone stock cars are hitting faster. For your conditions and map2, you're on the low end of the ball park. Set it to map0 and retest with your dragy, but also make sure to log runs as well. That will help show the boost numbers you're actually hitting.
Old Jan 3, 2019 | 05:31 PM
2019 C43 AMG
I didn't buy the BT adapter to change the Maps
Old Jan 3, 2019 | 05:34 PM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
U can do it with the data cable also.
Which is a cheaper option
Old Jan 3, 2019 | 05:47 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Looks good to me!
Old Jan 3, 2019 | 06:11 PM
2019 C43 AMG
Yeah?
Originally Posted by BMS
Looks good to me!
Old Jan 3, 2019 | 06:40 PM
BMS's Avatar
BMS
2018 C63 Sedan
Yes, but if you want to really dig in to it, record JB4 logs of the runs!
Old Jan 3, 2019 | 06:54 PM
2019 C43 AMG
I guess I need to by the cable
Can I assume, summer tires, 94 octane and warmer summer temps will result in faster times?
Do those current numbers reflect a increase in HP over stock? I guess I just want to know if the installed JB1 is in fact giving me the gains as described.
Old Jan 3, 2019 | 07:32 PM
BMS's Avatar
BMS
2018 C63 Sedan
Numbers vary dramatically based on a lot of factors. With the cable or blue tooth adapter you can go to map0 for a stock run for back to back comparisons.
Old Jan 3, 2019 | 07:42 PM
agchenry's Avatar
2018 C43
Best 0-60 times you will get will likely be in colder temps than hotter temps. I would suggest you splurge on the $100 upgrade and the Bluetooth (if you have an upgradeable unit) and with finer tuning take at about 1/2 second of that 4.5 posted time in that DA. Many factors involved to get your best time. By logging your runs, you would be able to tell what adjustments you need to make to get your times closer to 3.xx seconds. My $.02 Gl, and enjoy your ride!
Old Jan 3, 2019 | 07:44 PM
agchenry's Avatar
2018 C43
Started writing before your post. Lol what ^ said
Old Jan 3, 2019 | 09:46 PM
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
- running 91 Octane
I think that time looks super slow. Sorry to say. I did 4.5 with a JB1 Map2 on dragy as well. But I am in a GLC43 and it was 65 degrees at the time with 71% humidity. Also my front tires were changed 1 week after that run.
I brake boosted to 2200rpm.
Old Jan 3, 2019 | 09:49 PM
- running 91 Octane
I brake boosted to 2200rpm. Also, your default map should be map 1 not 2. But I do not know if you will be able to gain anything from map2 if all you are able to get is 91 octane.
Edit: I know you were on winter tires and 91 octane but still seems a bit slow. Was the floor very wet? If the floor was very wet, then 4.5 with JB1 on Map1 seems like a reasonable time. Did you have a passenger?
Old Jan 6, 2019 | 02:34 PM
Star4life's Avatar
2017 C43 AMG
ive done 4.2 stock and 3.6 with jb4. how are you launching? the launch in the c43 is an art that you need to master to get good times.
is your traction control on? you could be slipping in colder weather and throwing the traction light.
id run a map0 and compare to see the gain.
Old Jan 6, 2019 | 09:37 PM
AMG C43 3LV6's Avatar
AMG C43 3LV6
Do you regularly get 4.2 stock ? Is this your best? Whats your average?
Old Jan 7, 2019 | 09:57 AM
munis's Avatar
2021 Mercedes C63s AMG Coupe
These are mine:
Averages anywhere between 3.4 to 3.5. Dips to 3.3x when everything is perfect.
Old Jan 10, 2019 | 03:55 AM
MarcusDubya77's Avatar
Veteran: Army
19 C43 Coupe, XC 60
Nice numbers!
Old Jan 10, 2019 | 08:59 AM
2019 C43 AMG
I have to agree...the time seemed slow compared to what I was seeing others run. I just chalked it up to winter tires, cold weather, and higher altitude. As i posted originally in Vancouver a month ago..the car felt remarkably faster.
Would a defective JB1 be possible? I don't have the cable to change the map, so maybe I'll have to figure out how to unplug it and test it from stock.
Old Jan 10, 2019 | 09:03 AM
2019 C43 AMG
Update:
Ran a 4.20 the other night. I guess it's going in the right direction.
