AMR article regarding turbo size
https://shop.amrperformance.com/2019...-benz-c43-amg/
Makes me highly suspicious of their results. My 2019 doesn't feel less powerful or torquey in daily driving than my 2018 did.
What doesn't add up is the beginning of the dyno curve. The 2019 seems to show massive lag at low rpm, something we have not seen on any other C43 dyno charts. I’m assuming they messed up the graph.
We do not have a definitive answer on turbo size, but we do know the 2019 makes slightly more boost. I would guess 1 to 2 psi. AMR claims 11 psi for 2018 model, but they make 12 psi stock form. Here is a link to MBUSA. Their info doesn’t make sense either, as they claim 16 psi and there is no way the 2019 makes that from the factory. https://media.mbusa.com/releases/the...-amg-c43-sedan
Quote: “The AMG-enhanced 3.0-liter V6 biturbo engine boasts a high power output combined with low fuel consumption and emissions. The high power output is in part courtesy of separate, larger turbochargers (max. charge pressure 16 psi). Installed close to the engine, the two turbochargers are especially spontaneous in their response. The AMG power unit can be identified by the engine cover with red aluminum insert and AMG lettering.”
Bro...just think about it...they are the same engine and turbos are exactly the same...
the 2018 made 362bhp @ 11/12psi stock. If the new 2019 C43 allegedly has larger turbos AND 16psi, is it really only going to make 390? You've been around the forums long enough to see that all these piggy backs are claiming like 400/430 bhp with their units. That 430bhp is with stock turbos and tacking on 4-5psi.
The JB1 adds a max 5psi around 5000rpm on map2 on stock turbos and does like 0-60 in around 3.8
2019 C43 allegedly has 16psi on larger turbos and does 0-60 in 4.1 in the most generous publication?
Huh?
They are the same size turbos bro....just extra boost....
The 2019 C43 didnt cost any more than the 2018 C43 either so its not like you paid extra for something you didnt get.
This also calls into question whether or not the E43 has larger turbos, which has also already been speculated to the same degree.
Huh?
To be honest Benz has been doing this sort of "Half-Lying" for a long time. Like taking regular mercedes brakes off of an S-Class and putting them onto a C55 and printing AMG on them.
I will just say, like somebody already said above, the math does not make sense. The regular turbos at 16psi already make more than 390hp. Having 16psi with larger turbos should undoubtedly generate more than 23 additional hp. Otherwise, why add larger turbo chargers at all? It makes zero sense.
Any one of these parts could be marginally different in order to get the somewhat different results.
AMR's testing makes absolutely no sense. 1. they probably did not do back to back testing where the dyno was calibrated the same. 2. the only way the results they have posted are realistic would mean there is a turbo difference in some shape or form.
Either way, we need more information - preferably from a different source than AMR.
If the 2019 turbos are the same as the ones for the 2018, fine. They may very well be. It's a shame that AMR just isn't reputable or credible so it makes it so that you have to take what they say with a couple spoonfuls of salt.
Besides why put money into a motor that is destined to be replaced by an MB straight six twin tubo in future AMG models?
"Turbo size is only a small variable in a tuning equation"? Where do you get your information? Tell ya what buddy you can get a small turbo and I will get a large turbo and we can see who can make more boost, lol. Engine size and Turbo size are the two major factors in making high horsepower, compared to minor tweaking through tuning.
FYI the second half of my post was rhetorical, But your unwanted input was appreciated - not
You can tune a piano but can you tuna fish
Last time I checked, the true enthusiasts on this board want the most amount of power, they can possibly squeeze out of this application- so efficiency is not in the equation. Haven't heard of a lot of AMG owner wanting efficiency
Nobody is misunderstanding what you’re saying. We all get it. Tuning make a big difference also.
But you are seriously seriously reaching.
The only thing some folks, me included, want to know is who is providing factual info. If you have seen both turbos then please expand on the differences, or lack of...If not, then your are only adding to the speculation. ..
For the 2019 C43, it's possible that IHI changed the CHRA or even one of the wheels. Until someone pulls one out of a 2019 and actually disassembles it we will not know with 100% certainty whether the turbos in the 2019 are, in fact, larger or different. There is a lot of conflicting info from Mercedes AMG on it, and AMR hasn't presented a truly genuine set of evidence to dispel the speculation. Again, until a reputable, credible source (and that ain't AMR) comes forward with actual proof, this debate is far from settled. Does it really make a lot of difference, or does it really matter? That is up to the individual owner that wants to tune their car.
