Whining noise 2017 C43 Sedan while coasting - thoughts?
They MB Germany will not cover the third replacement at their dealership so I will be out of pocket if I insisted.
Sorry to hear about the negative experience with BMW, at least glad they fixed things for you.
Honestly as crap as the BMWs were, their customer service was better, so it’s a wash between the two. I will never own another Bavarian Money Waster though as long as the Quandts are the biggest shareholders. Had I known about them a long time ago I definitely would not have even had a single BMW. But that’s way off topic and discussion for somewhere else.
The dealer replaced the diff last week and the noise still is there.
rear diff part # 213-350-07-01
Dealer notes:
CONFIRMED CUSTOMER COMPLAINT, PERFORMED ROAD-TEST FOUND NOISE PRESENT ON SMOOTH ROADS ON DECELERATION NOT TIRE NOISE OR WHEEL BEARING NOISE SUSPECT REAR DIFF, LIFTED VEHICLE PUT VEHICLE IN DYNO-MODE, HAD VEHICLE SPUN TO 100KM/HR CHECKED HANGAR BEARING AT DRIVE SHAFT VERY SLIGHT NOISE, CHECKED REAR WHEEL BEARINGS NO NOISES, CHECKED REAR DIFF FOUND REAR DIFF MAKING LOUD HOWLING NOISE. SUSPECT NOISE IS TRAVELING TO HANGER BEARING.
Do you have the front differential and driveshaft part numbers that was replaced as well?
Can you throw here a quick guide what could be wrong?
I lived with the sound and just decided it is the characteristic of the vehicle.
