C450/C43 AMG
Has anyone tracked their 43?
Old Jul 21, 2019 | 04:36 PM
vanya.dx's Avatar
C205 C43
Originally Posted by RY_THE_AMG_GUY
run flat tires
not for track at all
P.S. what was max temp at front tires?
Old Jul 21, 2019 | 04:54 PM
RY_THE_AMG_GUY's Avatar
c43
2.6 max
Old Jul 22, 2019 | 03:07 AM
Nardoswiss's Avatar
AMG in drag
The stock recommended pressure on 19 inch is 39 psi cold. which is 2.7 bar. How do you come up with 2.0?
Old Jul 22, 2019 | 07:40 AM
c43
The car was sliding all over the place so figured the tires were too hot at 39 psi. Plus there seems to be some miscommunication as to what the car manufacturers recommend and what the tire manufacturers recommend. Keep in mind that the car manufacturers are recommending a specific psi for street driving which is completely different when tracked.
Old Jul 22, 2019 | 08:07 AM
AhEmGee's Avatar
2004 E55 K Wagon &. '96 SL500
When driving on track you nee much lower static pressures before starting the session, as the tyre temp will increase a lot, thereby increasing air pressure within the tyre further.
If you start with stock pressures they will get way too high during Track use, comprising grip, handling and the sidewall etc
Race cars will usually have a static pressure of 20-25 PSI at the start.
Old Jul 22, 2019 | 08:10 AM
c43
Agreed. However you can't run that low PSI in the stock run flats ContiSportContact 5 that come on the car.
Old Jul 22, 2019 | 08:12 AM
  #32
AhEmGee's Avatar
Mine has 19" RF with Pirelli P Zeros.( in the UK)
Old Jul 22, 2019 | 08:14 AM
  #33
c43
Better tires however it seems the RF can't take the abuse under heavy breaking and cornering.
Old Apr 10, 2020 | 02:23 AM
  #34
Ryansanders212's Avatar
C43 Amg Coupe 2017
Michelin Pilots sport 4s are by the far the best tires on this car.
