C450/C43 AMG
First mods order going in: Need your help picking ECU plz
Old Aug 3, 2019 | 02:13 PM
jim04clk's Avatar
I heard JB4 does not work well on 19’s. And from my experience for some reason every seems to be different with JB4. Even on other platforms. Audi guys having issues with it. Renntech will be my choice in the spring.
Old Aug 21, 2019 | 01:38 AM
IdC43's Avatar
C43
AMR is a joke... sent my ECU to them 3 times and everytime my car was not even driveable.. ended up paying to put my ecu back to stock... complete waste of 3500$ and month with car down.. and they kept giving excuse after excuse as to why their tune wasn’t working and that it wasn’t their tune it was an electrical issue with my 2019 with less than 1000 miles... they told me to take the car to dealer.. once sealer confirmed no electrical issues.. AMR then stated my car wasn’t running with their tune because of a small plastic clip that was broken that the dealer later confirmed has nothing to do with the car or the way it runs just a piece of plastic... AMR and Matt are very unprofessional and blocked me on Instagram.... childish... all because I paid them $3500 to tune my car and they couldn’t even do tune it ...
Old Aug 21, 2019 | 02:47 AM
xX G Xx's Avatar
Tuned '18 C43 coupe & Stock '18 GLE43 coupe
YIKES!
People still sent their ECU in for flash now? They opened up your ECU?
Hope you got your money back....
Old Aug 21, 2019 | 02:51 AM
xX G Xx's Avatar
Originally Posted by munis
The number of blown C43s tuned by the other tuners are scary to say the least.
.... so... how many blown C43's by ECU tunes you counted??? I'm curious...
Old Aug 21, 2019 | 02:57 AM
Spaggettio's Avatar
C43 AMG
thank god I went to a local tuner here in Sydney Australia. gained 60HP and 110NM.
I was going to get the handheld from AMR..... so glad i didnt.
Old Aug 21, 2019 | 09:00 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
While I am very much pro-JB4, I'll comment again from a neutral, devil's advocate perspective - if BMS arguably has things the most dialed in across any of the tuners, pre or post facelift, what makes you believe the Renntech is any better? Does Renntech have the community communicating with same level of feedback and collaboration between users? I honestly don't know. If you're waiting until spring to lay down some more miles before tuning, a reassessment of the landscape would be worthwhile again before buying anything.
Enjoy your car and good luck
Old Aug 21, 2019 | 11:25 AM
  #32
munis's Avatar
2021 Mercedes C63s AMG Coupe
7 to 8 I think.
Old Aug 21, 2019 | 11:35 AM
  #33
KyleSmith's Avatar
2019 C43 AMG Coupe
I did a Renntech ECU+ tune to my 19' coupe a few months ago, and I can say that you definitely can feel a difference. I went with Renntech because I feel like they are the safest option when tuning.
Old Aug 21, 2019 | 11:47 AM
  #34
munis's Avatar
You are not wrong. They are the APR equivalent in the Mercedes tuning world. They do things properly with R&D backing up each car they tune. More than that I know for a fact the main guys are Renntech are very well connected with some AMG programmers and engineers. Do not think Renntech engineers do not know how to crank up the boost and make more power, they consciously choose not to cause they know better.
I consider JB4 safe as well because of the simple fact that I can switch between the maps. Meaning, on a hot day, I go to Map 0 and run the car stock, with no additional stress on the engine. On a cold and dry night, I turn the map up, that too if I am feeling the need to go faster, cause the cold air can offset the cooling required for the higher boost levels. Most of time I just use Map 1 to get a mild bump in performance. And all this I have the luxury to do from my cellphone. So I would say the JB4 is just as safe. In a group of 50 to 60 guys in our JB4 whatsapp group, we have had no blown engines or turbo so far. And some of the guys there drives their car downright crazy.
Old Aug 21, 2019 | 02:00 PM
  #35
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
I consider JB4 safe as well because of the simple fact that I can switch between the maps. Meaning, on a hot day, I go to Map 0 and run the car stock, with no additional stress on the engine. On a cold and dry night, I turn the map up, that too if I am feeling the need to go faster, cause the cold air can offset the cooling required for the higher boost levels. Most of time I just use Map 1 to get a mild bump in performance. And all this I have the luxury to do from my cellphone. So I would say the JB4 is just as safe. In a group of 50 to 60 guys in our JB4 whatsapp group, we have had no blown engines or turbo so far. And someone the guys there drives their car downright crazy.
Agreed!
You should see how I rape all of my cars all in the name of testing and development
I blew my 335i N54 motor pushing 850+whp at 44psi... I found that limit LOL!
-Payam
Old Aug 21, 2019 | 03:13 PM
  #36
jim04clk's Avatar
I’m just waiting till the spring. 1st oil change. I will probably have around 1300-1500 miles. I’m gonna do Renntech. JB4 not for me. I’m just a set it and forget guy. I’m not going to be disconnecting sensors when I have an issue and need to remove. I will just unload the tune and take my chances. If they wanna get you. They gonna get you. My dealer is really cool and I don’t believe I’m going to have an issue regardless.
Old Aug 21, 2019 | 11:02 PM
  #37
b6tbfmp's Avatar
Mercedes and BMW
I am trying to understand what you said, by chance did you before removing the ecu and allowing the car to sleep? What is the plastic clip you are referring too? How did this get brought into the conversation with you and AMR? I am sure AMR would have flashed your ecu back to stock without a fee or was it flashed somewhere else?
I am out in Cali and have sent my ecu to them half dozen times and Matt goes out of his way to ensure great customer service and experience. Not once I experienced any unpleasantness or ecu related issues. I am sorry you didn’t get the tune you wanted but there are times the removal process could affect the ecu. The two harnesses that goes into the ecu, when you unplugged them, could it possibly be bent when you reinstalled the harness when you got the ecu back? I have seen harnesses go back into electrical components and cause something to happen, but you did indicate the dealer couldn’t find an issue. Good luck and hopefully you get your tuned.
Old Aug 21, 2019 | 11:19 PM
  #38
xX G Xx's Avatar
7 to 8 I think.
Wow.. i guess these folks don't like to talk about it... or signed an NDA...
Nice! Wonder what kind of Dragy times a Renntech tune can do. I understand is a "safer" tune back by MB, but some actual performance times would be interesting...
Anyone look at the Brabus tune?
Old Aug 21, 2019 | 11:39 PM
  #39
IdC43's Avatar
C43
Im assuming you don’t have a 2019... as I said I have friends with 17-18 that have no problems.. as for you saying it’s my fault for removal... I replaced no electrical/ plastic clips... car is now HD tuned and runs fine... they have something to hide they wana block me and have my post removed...
Old Aug 21, 2019 | 11:41 PM
  #40
IdC43's Avatar
C43
AMR keeps deleting my post when all I’m doing is stating truth and facts trying to warn other 2019 owners...
Old Aug 22, 2019 | 12:12 AM
  #41
b6tbfmp's Avatar
Mercedes and BMW
Yes, I dont have a 2019....I did not say its your fault as I asked you questions tactfully about how it was removed and the plastic part so I am trying to connect the dots in the hopes in helping you. At no time I wrote a response to point the finger at you. I am happy to see that your car is running fine.
Old Aug 22, 2019 | 08:19 AM
  #42
alexasa's Avatar
c
this guy has some sort of affiliation w/ AMR - just ignore and move on.
Old Aug 22, 2019 | 08:20 AM
  #43
alexasa's Avatar
c
We need a tune that was designed for 2019 - not adapted from the previous. Something is different about the turbos or some supplemental equipment that affect how the turbos work.
When that happens - i'll be willing to try it out.
Old Aug 22, 2019 | 08:35 AM
  #44
JonWu's Avatar
C43
Yes. Drive the car stock for a few thousand km and enjoy it as it is for a while. At no point did I ever feel that a stock C43 is slow. If you get bored after a while only then get the tune. Renntech is a great choice.
Also if you are driving only a few miles everyday, you car is not even getting enough time to warm up to working temperature which will allow you to push it. Go to AMG menu and wait for the temperature numbers to turn white from blue before you start pushing the car.
I have no idea why you are opposed to JB4, but in your requirement, it is the perfect tune for you. Cause you keep it in Map 0 (stock) for daily driving and if you are going for extended drives, only then switch to higher maps. It is still one of the fastest tune for this car when you want to be fast, and when you want to be stock you can be stock. All this you can do in seconds from the mobile app. But either way Renntech is a fantastic tune too.
I'm a newbie at the whole tuning thing, but with a piggyback tune like JB4, what does the car actually display for HP and torque when you put the screen to see that? Is it jibberish since the piggyback is altering the inputs to the car?
Old Aug 22, 2019 | 09:00 AM
  #45
munis's Avatar
It is not jibberish exactly. It shows the same numbers are the car would have done stock. Nothing changes.
Old Aug 22, 2019 | 09:08 AM
  #46
munis's Avatar
Old Aug 22, 2019 | 09:46 AM
  #47
munis's Avatar
Old Aug 23, 2019 | 07:20 PM
  #48
CA400's Avatar
C400
Your last sentence is correct. Renntech knows what they are doing. Their tunes for Mercedes is the most tried and tested from their own R&D. Other tuners just builds their map on canned tuned from Europe which usually made by a guy a working in sweatpants there. If you do not like piggyback and need to have a full ECU tune, go with DME or Renntech. The number of blown C43s tuned by the other tuners are scary to say the least. Till now it is only JB4, DME, Weistec and Renntech tunes that did not break these cars to date.
Just curious, who has met this guy in Europe in sweatpants? I hear this a lot about all tuners getting canned tunes and making them their own. Is there any evidence on this, where did this arise from?
Most of us here are car enthusiast and not tuners, so do we really know what goes into getting a reputable, safe strong tune?
Not starting a war, but a conversation.
Alex
Old Aug 23, 2019 | 07:46 PM
  #49
GuardianVA's Avatar
'19 C43
Alex
The part about canned tunes is absolutely correct. For European cars (and other makes too), there are three main tune developers that virtually everyone gets their "base" tunes from. These are essentially tune warehouses that sell files. Some tuners take these files and tweak them through in-house testing, others just roll with the canned tunes they bought and slap their name on it. Much of the real r&d and ecu cracking is done by these "warehouses. "
This is the reason you usually see similar problems pop up across multiple tuners for the same platform (i. e. The torque limit codes that all the flash tuners had early on with the C43).
Old Aug 23, 2019 | 08:07 PM
  #50
munis's Avatar
Bang on. None of these canned tuned had the torque limiters properly calibrated. How did these guys fix it then? Only way they know how. i.e Turning every single sensor off.
