C450/C43 AMG
PE flap angle in Comfort Mode and Exhaust Off
Old Jul 27, 2019 | 10:47 AM
TModelle's Avatar
C190
Those of you with PE, with Comfort Mode On and Exhaust Off, what do you recon the flap angle is from idle-4000rpm and above 4000rpm? I’m working on a controller and want to establish a baseline. I don’t think the flap is completely closed in any mode and at any rpm.
Old Jul 29, 2019 | 09:58 AM
munis's Avatar
2021 Mercedes C63s AMG Coupe
Around 45 deg
Old Jul 29, 2019 | 10:04 AM
TModelle's Avatar
C190
Originally Posted by munis
Around 45 deg
Throughout the rev range (idle to redline)? Or only at a certain range.
Working out the baseline, so Comfort Mode, and Exhaust Off - which would be the quietest setting.
Old Jul 29, 2019 | 04:42 PM
munis's Avatar
In comfort it opens halfway above 4000., in sports + it opens fully above 4000 and halfway before 4000.
Old Jul 29, 2019 | 05:32 PM
TModelle's Avatar
C190
This is with exhaust off or on?
Old Jul 29, 2019 | 06:03 PM
munis's Avatar
Comfort exhaust off sports + exhaust on
Old Jul 29, 2019 | 08:04 PM
TModelle's Avatar
C190
Got it. So to summarize, we have:
Comfort Exhaust Off, 45 degrees (Halfway) above 4000rpm.
Sport+ Exhaust On, Halfway below 4000 and Fully above 4000.
What about Comfort Exhaust Off below 4000rpm? Quarter way open maybe?
Old Jul 30, 2019 | 10:09 AM
munis's Avatar
Fully closed in comfort below 4000 rpm unless you have pushed the exhaust button on comfort.
Old Jul 30, 2019 | 10:10 AM
munis's Avatar
I dunno if you are aware, you already have a module for controling the valves aftermarket. its from ASR. Dunno if you knew about it so I thought I should point it out.
Old Jul 30, 2019 | 10:14 AM
TModelle's Avatar
C190
Got it, Thanks.
I will check it out!
Old Jul 30, 2019 | 04:57 PM
ASH_C43's Avatar
AMG C43 sedan
Is it true that "fully loaded car drives with closed exhaust valves can damage the engine"?
If so, then what about the aftermarket exhausts that only control the valves based on a simple on/off switch?
Old Jul 30, 2019 | 05:43 PM
munis's Avatar
Restrictions more than OEM design will cause damage.
Old Jul 30, 2019 | 06:21 PM
ASH_C43's Avatar
AMG C43 sedan
Let's say OEM PE exhaust but 100% closed (no half open, etc.) even at high RPMs.
