BMS Intake Review
they also probably had the hood open which would drastically benefit the BMS system but have a null effect on the OEM airboxes (this is speculation)
source: https://burgertuning.com/collections...nting-hardware
I'd like to see before and after Dragy runs with and without BMS.
Here is something that a Mr. Chris Chen collected & post on the FB page. Temp is in Celcius.
Not sure what OP was expecting when he purchased the intake. The dyno's been published for months. The temp difference vs the HP gain was questioned a million times. The design was clear to see. The filters are still sitting in the hottest area of the engine bay. Plus, you now got metal piping connected directly to the hot turbos. Cold air does not magically appear when you are sitting in 100F heat while your engine is cooking @ 1000. Cold air does not magically appear even if you are cruising in 100F heat.
.For your reference, the fastest C43/450's now are on BMS intakes.
That is the million dollar question.
If it did, we would have designed it just like that. These heat shields for the C63 attach directly to the front snorkel
The purpose of intakes are to eliminate the restrictions within the systems, that's where you get the most gains.
Putting them in a cooler better place aids that, but we're limited with the space given.
-Payam
@TModelle did you end up going back with OEM intake? I mean sounding like a bad toilet is pretty awful
Heat would rise away from the Air Filters
FWIW i did a bunch of 20+min logs of my ride home traffic with and without the gold tape and saw about a 9° avg drop post heat reflective tape. Dont have any logs from before intakes or wrapped DP's.
