BMS Intake Review
FWIW i did a bunch of 20+min logs of my ride home traffic with and without the gold tape and saw about a 9° avg drop post heat reflective tape. Dont have any logs from before intakes or wrapped DP's.
I just ordered mine for the c400. Will definitely use the Heat reflective tape, but curious if this way of installing has helped?
I'd like to get mine installed to be as effective as possible
that's another reason. Sound is what you hear gti's produce with a blow off valve.
Basically it seems as if the extra air is just over working the blow off valve's and ends up not producing more power because the air is too hot. So - all bad.
The amount of air at idle being consumed is misleading- as looking at 1ATM, "gallons" of air sounds like a lot. At idle, the disruption of ambient air in the engine compartment by the intake is minimal at best- but heated air finds it way upwards easily and unrestricted. A 3 liter engine at idle could easily consume all the air it needs from a 3" diameter single tube and you'd only slightly feel the suction if placing your hand near the end of the tube. Keeping the air filter and intake tubes from getting hot and retaining heat is by far the most important part, because objects retain heat. As soon as cooler air is available, the temps will come down instantly if not being also "charged" with the task of cooling the hardware down as well.
A vented hood would do wonders, and at speed the high pressure that builds towards the rear of an engine compartment would vent extremely well if given somewhere to go. Since the lower bumper in the "fog light" area- despite the fact we have no fog lights there- is blocked off from the factory, so I'm considering the aftermarket trim parts that open those areas up to allow air to come through.
Looking forward to seeing how it all comes together. I swore I wasn't going to mod this car much, but as always- it's a slippery slope. Now looking at high flow cats and going from an EC stage 1 to a stage 2.
Intakes are installed. Passenger side heat shield didn't fit well at all... it sits high because of some pipes running on that side of engine- couldn't get even close to installing the front bolt on the shield, even with the provided spacer. That filter has to sit higher because of it as well. Initial thoughts are that it makes a lot more turbo noises and despite cautioning myself not to let placebo effect sway my perception- throttle response seems quicker. I used an adhesive heat shield on the pipes and the bottoms of the heat shields, and intake temps are reading the same delta from ambient that they were with stock airboxes. I'm sure they'll climb when stopped, but initial runs at city and highway speeds show the same difference. All in all, I feel the kit is overpriced for what it is... which keeps me from being super happy with it. Overall I'd give it an "ok" if you've got some $ burning a hole in your wallet. The heat shield not fitting was interesting, considering I haven't seen anyone else comment on that.
