How does C43 change the intercooler?
By design it will be harder to replace, as its located much closer to the engine block, reducing piping length and therefore reducing turbo lag.
The MB garage went in from below which meant they cound do it in only 4 hours. So unless it is because you are modifying, I suggest you get MB to do it. They replaced mine and the circulation pump for the LT circuit with materials and 2 hours worth of fault finding and a readout for USD 1400.
