C450/C43 AMG
W205 c450. Outside door handle came off. How to reattach?
Old Sep 8, 2019 | 01:43 PM
buzzinhornets's Avatar
2018 C300 4MATIC (W205)
I assume the metal bars inside door need to slide into plastic gaps... but how without forcing them?
Old Sep 9, 2019 | 11:23 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
You'll need to pull the interior door panel to reconnect everything. However, seeing as the door handle is obviously not meant to be removed, I doubt you'll be able to simply pull the panel and reconnect. Something is more than likely broken internally that will need replaced.
Old Sep 27, 2019 | 08:58 PM
Fyi, dealership under warranty said screw wasn't torqued. Found screw in door. Reattached with lock tight screw glue. All good. Cost zero.
