C450/C43 AMG
Joining the crack club!
Old Oct 15, 2019 | 09:34 PM
mcschan86's Avatar
C43 Coupe
Hi guys. I joined the cracked OEM rim club today! Welcome myself...
19" AMG rims, 2017 C43 coupe
After getting 2 ruptures on the rear driver's tire a month ago, I find my front passenger tire losing 15 psi over night. I drove it to work with 23+/- psi but it greeted me with 8 psi when I came out of the office at the end of the day.
A shop had a look at the tire but reported back with a crack at the lip of the inner side of the wheel; crack is on the sidewall of the flange. I must have ran over a large pothole a couple weeks ago but not sure why it didn't start leaking then.
My plan is to switch to my winters early and then have a bit more time to decide what to do with the damaged wheel.
Do you guys just repair the cracked wheels at a shop? Weld? I suppose this would compromise the material strength; have you guys seen any re-appearance of the crack at the same spot?
Old Oct 16, 2019 | 05:29 AM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
i actually have a rim repair shop owner said to me, it' not safe to weld a cracked rim.
i bought a remanufactured rim on ebay.
Old Oct 16, 2019 | 09:30 AM
TModelle's Avatar
C190
Isn't a remanufactured rim likely to be a welded rim?
Old Oct 16, 2019 | 02:37 PM
netboy's Avatar
i been using the remanufactured rim for 8 months now.
no problem, no leaks or anything.
it' possible the remanufactured rim is from bent or scratched rim.
Old Oct 16, 2019 | 08:58 PM
Mr. J's Avatar
C450, GLC43
Bogus,
This is how you do it:
You just have to find a shop with a decent welder who's actually proud of his work.
