C450/C43 AMG
C450/C43 Suspension issue.
Old Dec 21, 2019 | 02:59 AM
C4fitty's Avatar
2019 AMG C43
So my car has an issue with the suspension. When I put the car in drive it automatically sets the suspension into AMG Sport. Pushing the button to change it doesn’t work at all. Even if I change the Dynamic setting. E to C to S to S+ the suspension doesn’t change. If I turn the car off and turn it back on and not put it into gear such as Drive or Reverse I can change the suspension setting fine. Once it goes into gear that’s when it just defaults to AMG Sport and nothing I do makes it any better.
Has anyone else has or had this problem before? It’s very frustrating that I can’t drive normally without some sort of stiffness constantly being in Sport mode. I called Mercedes and set an appointment to get it looked at.
Old Feb 6, 2020 | 07:19 PM
Pharmdood's Avatar
2016 C450
I had this same issue and my dealer had the car for three weeks. For me, it was the cpu for the airmatic suspension.
Fun facts that I learned, was when the suspension button defaults to one light on the left and does not respond to pressing, that this is an error indicator. At first the dealership was saying it was stuck in Sport suspension, but it was actually not functioning at all.
Old Feb 7, 2020 | 01:20 AM
hlieberg's Avatar
2018 AMG C43 T
I had the same issue with mine. It was an "accelerator sensor" on one of the dampers.
Pharmdood, I don't understand what you mean with "airmatic suspension", the C450/C43 doesn't have airmatic.
Old Feb 7, 2020 | 11:37 AM
Pharmdood's Avatar
2016 C450
hlieberg, so the part that the swapped out was "328559 Control Unit for Air Suspension (Airmatic)" per the dealership paperwork. Take from that what you will.
Old Apr 17, 2020 | 06:33 PM
MBC450AMG's Avatar
2016 c450 amg
Fix?
I’m having the same issue with my c450. Did you ever figure out what the issue was?
Old Apr 18, 2020 | 12:20 PM
SpeedingTicket's Avatar
C450
Mine (C450) had this same issue. The suspension control module had failed and the dealer replaced the module under warranty and it has been fine since. This was about three years ago. I can get the part number if it would be helpful.
Old Jun 14, 2020 | 09:31 AM
Nicholas Ulrich's Avatar
c450
Yes please, that would be a big help if you could get the part number. I just put out a post yesterday talking about the same problem on my c450. Do you know if that module seems to be the common culprit with other cars as well?
Thanks!
Old Jun 14, 2020 | 11:47 AM
C450
The part number is: 222-900-06-12. The tech noted that toggling the suspension control button resulted in no change to the suspension firmness indicator lights. He also noted that a code was stored indicating that there was no communication with the suspension module from the left front headlamp module (strange wiring Mercedes!).
As for how prevalent this problem is... good question! I only know that I am not the only who had to have this module replaced. After they replaced it (in 2017) the car has had no further suspension control issues.
Old Jan 28, 2024 | 12:16 AM
quantram1995's Avatar
C450
Can you please give me the number part? Thank
Old Oct 16, 2024 | 08:02 PM
benzc450amg's Avatar
hey i have 2016 c450 and the amg suspension light stays on and the car ride very bumpy and rough, is this similar to what you were experiencing? Please let me know the dealer was no help near me.
Old Oct 17, 2024 | 09:14 AM
SpookHolidae's Avatar
C43 AMG
Did our worst nightmares come true? Did the Mercedes Grinch install airmatic in our cars at night for being bad boys?
